[C2] Longer wheel studs
Longer wheel studs
Hi all I have a 66 corvette and I have put new willwood discs and callipers on the problem I have is the wheels no longer fit so I had to have some wheel spacers made wheels now fit good but I now need some longer studs only seem to be able to locate standard ones here in the uk if anyone could help that would be great first time on here so thanks Gus
Ginger66 (05-08-2019)
Check these out as an example.
https://www.titanwheelaccessories.co...iABEgIHqvD_BwE
Ed
First reason I needed new wheel studs were that the old threads were worn out. Also the bolt on knock off wheels have a cast aluminum thickness that is
more than the original steel rims have. So there were less threads for wheel nuts to tighten. With the longer studs it was a win,win for me. New threads and more threads for the longer nuts that came with the bolt on knock off wheels.
here's another example of recessed spacers (1 1/4" spacers): https://www.jegs.com/i/Trans-Dapt/969/3611/10002/-1
You can also buy longer studs, but they may not be as safe: https://smile.amazon.com/dp/B00TO5ZI..._t3_B000CIQZTU
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Welcome to the forum! Post some pictures. We all like to see new members cars.
Thank you! Very nice.
Received 1,126 Likes
The factory stud is 1 3/4" under the head, Dorman part number 610-157 is 2 1/8" under the head.
Joe
https://www.dormanproducts.com/p-243...origin=keyword
Joe
Ginger66 (05-09-2019)
