C1 Firewall Shield to keep temperature down
I have a 1957 that runs hot in the driver and passenger compartment, but the temperature gauge reads 160. That is down from 180 after I installed an aluminum radiator. I put an adjustable rheostat on the gauge to adjust it since I know that the Corvette temperature gauges can be inaccurate. However, after driving until the engine heats up the passenger and driver compartment get very hot. Is there material that can be put under the carpet that would keep the heat down? Any other suggestions are welcome. Thanks.
Maybe put some cutoff valves in the heater hoses in the engine bay - O'Reilly and NAPA sell them in most C1s they are two sizes 3/4" and 5/8"...
Via (05-26-2019)
Don't know alot about c1's and 2's, but on my c3 I glued some aluminum foil/bubble wrap under the carpet. I used that instead of the self stick dynomat because I'm told the dynomat has an asphalt smell. It made a huge improvement.
If the heat is from the heater core, I would think a new or better water valve would cure that. But then again, I don't know much about the earlier models.
Good luck,
Jeff
Good luck,
Jeff
Via (05-26-2019)
You have to really clean the underside of the floor and the lower portion of teh firewall, down to bare, smooth fiberglassglass, then apply this stuff:
https://www.summitracing.com/parts/hsp-721202
Mineral spirits and lacquer thinner and old rags work well for cleaning, after you scrape the big chunks off with a putty knife.
I used it under the floor, above the header collectors and exh pipes.
Doug
Doug
The following 2 users liked this post by AZDoug:
Loren Smith (06-09-2019),
Via (05-26-2019)
AZDoug,
Thanks for the tip. I contacted Summit Racing and ordered a roll of the material. It looks like the perfect thing to cut the heat along with putting shutoff valves in the heater hoses.
What did you use to tack the carpet back down?
Via
Via
The self adhesive stuff from Summit, went underneath the car, between the floor pan and frame. I figured best to keep teh heat from even getting to the floor pan
What I did inside the car was lay a layer of something similar to this under eth carpet:
I don't glue down carpet in a C1, the door sills and kick panels hold it in place.
I do put four screws with trim washers on the tunnel piece, way down low to keep it in place where you can't see them anyway. The center console carpet piece on my '61 isn't going anywhere once the trim strip is installed. You could use trim screws and washers that are covered by otehr carpet piece edges if necessary
You can also apply insulation and dyna mat on the insides of the fenders behind the kick panels and up to under the dash, and inside the doors if you are so inclined.
It knocks the noise down quite a bit.
My Corvette sounds more like a Cadillac inside, than a C1.
Doug
Doug
Via (05-29-2019)
Nick
The following 2 users liked this post by Nick Bernier:
Via (05-29-2019)
Doug
Doug
Very detailed and helpful description. I received my order of heat shielding and will put that under the carpet. I'll take your advice on holding the carpet in place. Thanks a lot!
Its not your dads Corvette, anymore.
I really do need to put in a 4 speed auto trans, manual shifting the 5 speed slows the car down, too much.
Doug
The following 4 users liked this post by AZDoug:
Via (05-29-2019)
Only if you can see them.
OTOH, they look better than munged up tower clamps and are easier to deal with that spring clamps in awkward locations, so I do my best to pick a nicer looking worm drive clamp, keep it spotless and make sure the clamp is sized for the hose so you don't have a long tail hanging out, and position the drive mechanism underneath the hose out of view, if i can.
Doug
Doug
Via (05-29-2019)
You could but my though was that the outflow hose would still be connected to the car's "hot" coolant system and not completely isolated. Also, if your heater core ever blew you could slam both valves shut and make it home...
Via (06-13-2019)
Location: Las Vegas - Just stop perpetuating myths please.
You can insulate and isolate everything but if your shifter boots are cracked and leaking hot air from the transmission tunnel your still gonna cook more than your legs. Same goes for your heater box seals. My corvette is 20 years newer than yours and all my heater box seals were trash. Now the monkey poop they use on the outside of the heater box is a pain just to remove and even though you can still buy monkey poop seal I used RTV to reseal the box. That was my choice and I don't regret it - yet.
Have fun.
Have fun.
Via (06-13-2019)
Doug
