[C2] Spare tire
Spare tire
Can someone help me with the correct tire size for the spare tire on a 64 Vette? We just discovered that the standard tire size does not fit. The old spare tire said low profile. Thanks! And where to purchase the spare tire?
JD, I recently went through the vary same thing with my '64. Like an idiot (thought I was being smart) I ordered five new radial tires with the fifth being for my spare. 205-70 R15. Didn't and will never fit in the tub. With the help from some of the guys here, this is what I did. I took my original wheel back to the tire shop, had them remove the new radial tire and mount and balance this tire.
It fits your standard 15 wheel, it's small enough to fit and big enough to help you get to a service station and it's cost is very good. Many guys look for the temp spare from a Chevy S10 (mid to late 90's model), but they have become hard to find and about the same cost of doing it this way. I hope this helps. Good luck.
Received 6,929 Likes
2015 C2 of Year Finalist
ALL five tires where the same size from the factory. however reproduction bias tires are not 100% correct in size and therefor will not fit fully inflated. the radial equivalent wont either.
jdeddy (06-21-2019)
64 Vette spare tire
https://www.amazon.com/Nankang-CX668...omotive&sr=1-1
Jim
Assuming you have the OEM spare tire tub and the original 5.5" width wheel, this suggested tire fits fine. The depth of the tub is roughly 7+ inches. The width of the tire when mounted and inflated is roughly 6.5", so it will fit without having to drop the lid down slightly to make it fit as suggested by one of the previous posts. Once again, if you have the original spare tire carrier, a 15x5.5" wheel you will have no problems with it fitting. Here is a picture of mine before I pushed it in and locked it down.
A big thanks to Pilot Dan. He was the one that suggested this problem fix and it worked perfectly.
jdeddy (06-22-2019)
2023 Restomod of the Year Finalist
Another question
spare rim
Where can one find a rim to work with the tire? This is not for a points car
