[C2] Does your C2 take a lot of effort to turn steering wheel
Received 1,843 Likes
Parallel parking is about the quickest way to get a car torn up bythe car in front and behind you.. But, if you like it, go for it.
Have you tried a few extra pounds of air pressure in the tires?
I have factory PS in my 63 with bias-ply tires I havent driven it in 2yrs but when I did it seemed like it was to easy. Jumping from my Nissan which is like a go kart steering to old GM is different.
Received 6,513 Likes
C2 of Year Finalist (track prepared) 2019
I know it's a subjective thing but it just seems like my car takes more effort then what I think it should. (This is the only C2 I have driven). I had been debating installing power steering but it seems like they should steer easier since the cars were made for men and women. The box was restored by me so that might be the problem but I used past threads to go by in adjusting. My restoration consisted of cleaning out box, new grease and gaskets. Everything else seem OK. It's a little snug when wheels are pointing straight but I think it is suppose to be like that so car will not sway. If I send it off, any recommendation who to send to, thanks
'63 manual with tie rods in slow position
'63 manual with tie rods in fast position (my daily driver for 12 years)
'63 PS with tie rods in fast position
'63 PS-DISABLED with tie rods in fast position
All of the above are/were easier to steer than my C1 with the caster shims.
For sheer ease of steering, nothing beats my '54 with no caster shims. That one is almost easy enough to steer with one finger (yes, except when stopped).
Just for info, when I got the car the tie rods were connected to the front holes. I think this is where they should be if you have power steering. When I moved them to the back holes, effort on turning steering wheel was a lot better. But I still need more ease.
Different subject. The related threads is a good idea I guess but at times I end up responding to a 4 year or older thread.
One of several threads
There have been several threads recently on the subject of PS on C2s. I added PS to my '63 and it is way too boosted. Seems GM used this assisted power steering on a number of platforms with different tuning to get the feel they wanted with each car line. Corvettes used a 55 pound spring in the control valve while passenger cars used springs that were as light as 20 pounds. After a lot of looking it seems that many of us with added or remanufactured valve how have a light spring and over boosted steering. Too bad one of our forum vendors can't get some of the right springs built and become a hero to those of us in need.
I'll continue to hunt for a used valve with the correct spring (adjustment nut cover has an X on it). If I can't find one it's off with the PS and back to Armstrong steering.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
You are right on the mark with this info and the reason many give the factory PS a bad rap. My 1965 has the original PS and I LOVE it.
I called Lonestar and told them I've read threads about the lighter spring being a problem. He said nonsense. The lighter spring works as well as the 50 pound. But, what else can you expect a vendor to say since they do not have the 50 pound. I've considered installing PS but would rather keep the car stock. That's why I started this thread to see if maybe a box rebuilt would give me a little more ease. From what I have read, it seems like the borgeson does not have as many problems as the original design but I do not like having to cut steering shaft or the looks of the unit installed.
#34
Received 2,250 Likes
I want to install PS. in my 67 L79. I even bought the Borgensen kit. The kit has sat in the garage for three years in the box. I am not a wrench whiz and fear I will either do harm to the car or get so confused or befuddled, that I will tear it apart and either just leave the car or really mess something up.
#35
Received 2,330 Likes
Much like Jim Lockwoood, my experience is similar:
I didn't find C2s difficult to steer at all and I've driven all of the following:
'63 manual with tie rods in slow position (for ten years)
'63 manual with tie rods in fast position (for 20 years)
While I didn't find C2s difficult to steer at all, my wife thought otherwise, and I installed more modern Borgensen PS three years ago and will never regret the upgrade.
#36
I want to install PS. in my 67 L79. I even bought the kit. The kit has sat in the garage for three years in the box. I am not a wrench whiz and fear I will either do harm to the car or get so confused or befuddled, that I will tear it apart and either just leave the car or really mess something up.
#37
You have to be a bit careful installing power steering, if assembled incorrectly the steering wheel can whip around to one or the other extremes swiftly - all the way to the lock... It happened to me when I screwed up putting a new power steering system on a '66 Mustang, did no damage, but it was scary...
#38
That is what I was referring to about centering and returning in my above post.
#39
2022 C2 of the Year Finalist - Modified
I agree. I have a 65 with factory PS and it is perfect. I cruise at 80 with a 14 inch steering wheel and it is perfect. I am in control, there is no steering wobble and the car runs straight and true. I can also easily parallel park.
#40
I think a factor many of us don't want to deal with is getting older with lessened upper body strength and loss of muscle tone.
There -- I said it. The accumulation of birthdays is the 'dirty little secret' that is tough for many of us to face head on.
I'm a fit 68 year old with no health problems and I hit the gym 3 days a week with weight training and I can feel the years still taking their toll. I'm no wimp but there are times when the 63 manual steering gets to me too, particularly in tight quarters.
I've had to move back and forth to park at some car shows and finally exited the parked car with sore "man *****".
Its not enough for me to go to power steering (yet) but the thought does cross my mind.... And every once in a while my left knee gets "creaky" after enough clutch depressions on a long drive. But no automatic for me...
I'll fight the good fight until I can't anymore...and I'm cruising around the grocery store in one of those "Fat-illac" scooters; all "pizzed-off" because I can't remember what shelf they keep the Maalox on.
The following 2 users liked this post by Frankie the Fink:
6D2148 (06-30-2019),
DansYellow66 (06-30-2019)
