[C2] Bang and Crunch Sound
Old 06-30-2019, 08:20 AM
MikeM
CF Senior Member
One things for sure. You can't just look at it and fix it. Do something.
MikeM is online now
Old 06-30-2019, 10:55 AM
Factoid
CF Senior Member
Factoid's Avatar
Originally Posted by 59BlueSilver View Post
We pushed the car into my shop, tranny in neutral, no resistance at all and no noise. Would that indicate the rear end is okay?
Get the rear wheels off the ground, push the clutch in and rotate the rear wheels while trying each gear and report back. Neutral isolates the input shaft and I think that is where your problem lies. Using the clutch to isolate the drivetrain includes the tranny input shaft in the test. My bet is you hear the grinding in every gear.
Factoid is offline
Old 06-30-2019, 10:58 AM
59BlueSilver
CF Senior Member
59BlueSilver's Avatar
I will, when I get a chance. Iím entertaining my grandkids right now. Hopefully late this afternoon.
59BlueSilver is offline
Old 06-30-2019, 04:32 PM
AZDoug
CF Senior Member
AZDoug's Avatar
2017 C1 of Year Finalist
Just don't do it too long, as the output shaft yoke is what keeps gear lube from leaking out the back of the trans.
Doug
Originally Posted by Kerrmudgeon View Post
Pull the drive shaft with it up on safety stands, start it up and run it through the gears to see if it's the trans or clutch, if it's ok then your know it's the rear end. That's what I would do.
AZDoug is offline
Kerrmudgeon (06-30-2019)
Old 06-30-2019, 04:57 PM
59BlueSilver
CF Senior Member
Originally Posted by ghostrider20 View Post
Does your clutch feel normal?
With engine running, trans in neutral, is the noise present?
Can you roll the car freely in neutral?
with engine of, can you shift through the gears normally?
YES to all those questions. What could it be?
The noise is only present when the engine is running and clutch is out, no noise when I push the clutch in. Everything looks fine for what I could see of the clutch.
Well, it’s definitely in the drive train and not something obvious or easy to fix, it looks like. I’ll have it towed to the shop tomorrow if I can get in. Any guesses what it might be so far? Sounds like the tranny to me.
Old 06-30-2019, 06:16 PM
Westlotorn
CF Senior Member
Support Corvetteforum!
Westlotorn's Avatar
I vote for MikeM's advice, put it on Jack Stands and gently try the clutch and gears. If all is quiet while the rear tires are spinning in gear apply a little brakes and see if all hell breaks loose.
If one gear is quiet try all the others, 1st, 2nd, 3rd, 4th and reverse. You should be able to easily stall your engine using the brakes without hurting any of your driveline. If you hear odd noises track them down.
They are either in the front or the back and will show up as you test.
Westlotorn is online now
Old 07-01-2019, 10:12 AM
vettsplit 63
CF Senior Member
vettsplit 63's Avatar
Location: Power tripping Sociopath- has a nice ring to it- I used to be a people person, but people ruined it Texas
St. Jude Donor '12
If you put it on jack stands, I would make sure to not let the rear end hang with the half shafts at an extreme angle if I was going to run it through the gears.
vettsplit 63 is offline
Westlotorn (07-01-2019)
Old 07-01-2019, 10:41 AM
MikeM
CF Senior Member
Yeah, if you don't have the right shocks on the car, not really a good idea if the shafts bind up.
MikeM is online now
Old 07-01-2019, 01:30 PM
GTOguy
CF Senior Member
GTOguy's Avatar
Received 1,247 Likes on 944 Posts
Does it make noise with the car in neutral and the engine running? Clutch in, clutch out, but in neutral?
GTOguy is offline
Old 07-01-2019, 06:41 PM
Pilot Dan
CF Senior Member
Pilot Dan's Avatar
He says it is making noise in neutral with the engine running If that's the case, get the front up on jack stands. Start it up and with a hose or mechanic's stethascope, you ought to be able to hone right in on the source of the noise. The noise can't be coming from the rear if the car is not moving.
Pilot Dan is offline
The following 2 users liked this post by Pilot Dan:
59BlueSilver (07-01-2019), GTOguy (07-01-2019)
Old 07-01-2019, 11:22 PM
59BlueSilver
CF Senior Member
I’m not going to take a chance on further damage by running it thru the gears, like taking out a cluster. The clutch feels very normal to me so I’m almost sure it’s the tranny. I’ve got it loaded on my trailer and taking it in tomorrow then we’ll know. BTW, when I was wenching it into the trailer, I didn’t hear any grinding or strange sounds.
Old 07-02-2019, 02:20 AM
ghostrider20
CF Senior Member
ghostrider20's Avatar
It is your transmission.
ghostrider20 is offline
Old 07-02-2019, 09:22 AM
  #33
Factoid
CF Senior Member
Factoid's Avatar
Iím not going to take a chance on further damage by running it thru the gears, like taking out a cluster. The clutch feels very normal to me so Iím almost sure itís the tranny. Iíve got it loaded on my trailer and taking it in tomorrow then weíll know. BTW, when I was wenching it into the trailer, I didnít hear any grinding or strange sounds.
The damage is already done, my friend. It didnít make any noise because neutral isolates the tranny input shaft and that is where your damage lies.
Factoid is offline
Old 07-02-2019, 10:55 AM
  #34
ejboyd5
CF Senior Member
ejboyd5's Avatar
Iíve removed and installed the T10 in my 59. Is removing and installing a Muncie in a 65 less effort, equal to, or more difficult?
More difficult because you're now older.
ejboyd5 is offline
59BlueSilver (07-02-2019)
Old 07-02-2019, 11:05 AM
  #35
vettsplit 63
CF Senior Member
St. Jude Donor '12
No kidding. Like all of us, when I was younger, I could lay on my back and press a Muncie up and wiggle it into position while keeping it from binding on the clutch disc. That is what they make transmission jacks for nowadays. Man that is hard to accept.
roju1985 (07-03-2019)
Old 07-02-2019, 03:30 PM
  #36
Dan Hampton
CF Senior Member
Dan Hampton's Avatar
2018 C1 of Year Finalist
If it is the input bearing, the cluster is probably already gone.
Dan Hampton is online now
Old 07-02-2019, 05:27 PM
  #37
MikeM
CF Senior Member
Yep but even if it isn't one of the reduction gears can take a cluster out.
MikeM is online now
Old 07-02-2019, 11:32 PM
  #38
59BlueSilver
CF Senior Member
I took it to a highly recommended transmission place today. He said with the holiday coming up we might not know till next week.
Old 07-03-2019, 01:26 PM
  #39
DansYellow66
CF Senior Member
DansYellow66's Avatar
Fortunately lots of good parts available now for rebuilding or upgrading an old Muncie.
DansYellow66 is offline
Old 07-03-2019, 01:29 PM
  #40
DansYellow66
CF Senior Member
I wonder if they have any one who has every pulled an old C2/3 transmission before? If not it would probably be entertaining to hear them cursing Chevrolet for building a car with a fixed cross member.
Quick Reply: [C2] Bang and Crunch Sound
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
