walt
Could be a dozen things, even an ignition coil...
But my first guess would be the choke sticking because the piston in the choke housing is frozen up...
Take off the air cleaner and while holding the throttle linkage in the wide open position work the choke plate back and forth on the rear carb and see if it binds...
Received 1,843 Likes
I suppose you do know that engine is supposed to idle a little rough whether hot or cold. Not supposed to stall though. Idle speed should be 750 or a little more, hot.
I’ve never gotten a set of C1 dual quads to idle nicely below 850 RPM on a solid lifter car.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,329 Likes
You would likely get more responses if your thread title was related to the subject matter in some way.
warrenmj (07-03-2019)
