[C2] race+street 66 build
Old 07-08-2019, 07:27 PM
  #41
reno stallion
CF Senior Member
Originally Posted by elwood13 View Post
That guy is a welding machine.
Yes to be young again
reno stallion is offline
Old 07-08-2019, 08:09 PM
  #42
Mike Mytro
CF Member
If you are going to race the car I would continuously weld the chassis instead of stitch or skip weld.
Mike Mytro is offline
Old 07-08-2019, 10:38 PM
  #43
reno stallion
CF Senior Member
Well why didn't tell me that yesterday
Old 07-09-2019, 04:38 AM
  #44
Westlotorn
CF Senior Member
Support Corvetteforum!
Westlotorn's Avatar
It all looks fantastic, can I ask how many spools of wire and tanks of Argon you went through? Very Nice work, I had never heard anyone mention stiffening the engine cradle before.
Can I ask how you cut the 1/4" line for the chrome moly addition? Plasma cutter?
Mark
Westlotorn is offline
Old 07-09-2019, 05:17 AM
  #45
roadster65
CF Senior Member
roadster65's Avatar
Seam welding the Chassis should provide torsional rigidity and reduce chassis flex or twisting under load, especially in corners; and help the suspension keep all four wheels planted to the road to maximise mechanical grip. You might want to take a file or grinder to some of those welds to clean them up a bit, aesthetics and performance or not mutually exclusive (just a thought) - pics follow might be a reference point for some build ideas - nice project - looking forward to the end result - Regards - GV
roadster65 is offline
reno stallion (07-09-2019)
Old 07-09-2019, 08:37 AM
  #46
solidaxel
CF Senior Member
solidaxel's Avatar
What is he using the propane torch for?
Pre heating the weld area?
solidaxel is offline
Old 07-09-2019, 09:06 AM
  #47
reno stallion
CF Senior Member
Mark
One big spool and not sure how much gas. The cut was made with a grinder with cut off wheel
Westlotorn (07-09-2019)
Old 07-09-2019, 09:10 AM
  #48
reno stallion
CF Senior Member
The frame was powder coated when I got it.Comes off easier with some heat then a wire wheel. It is pre heating though
Old 07-09-2019, 09:46 AM
  #49
reno stallion
CF Senior Member
I will clean up some welds and the frame will be off to the powder coaters. So lets get back to the body. When using a stock style chassis wheel size is usually limited the first thing is the spring and trailing arm. The frame is about even with the inner wheel tub. You can use a shorter spring and double offset trailing arms to gain about 1 1/2 inch inboard or run a 18" or bigger wheel with the stock length spring and offset trailing arms. I gained about 2" of room with the widened quarters. So with the chassis out of the car whatever room I have between the inside fender lip and inner wheel tub is what I have for tire size.
This is a 315-35-17 not what I would run because it has to be 18 or bigger to go around the spring. But it dose give me an idea of how much tire will fit. This fits with about a 1/2inch clearance on both sides
This tire is to short
Old 07-09-2019, 05:26 PM
  #50
roadster65
CF Senior Member
roadster65's Avatar
Reno; Nice body work, did good, the fenders look sensational, what colour have you in mind to paint ? - Regards GV
Old 07-09-2019, 06:42 PM
  #51
63 340HP
CF Senior Member
63 340HP's Avatar
When you integrate the cage it will make the chassis much stiffer.
Post weld heating and air cooling for stress relief does help fatigue resistance at weld junctions with chrome moly. I don't think heat can be applied to the hidden 1/4" vertical stiffener/shear panel in the cross member, not without risking elongation distortion, but it will help at future localized cage junctions.
I wish your welder/fabricator the best in the upcoming competition, and you the same with your car.
63 340HP is online now
Old 07-09-2019, 07:03 PM
  #52
reno stallion
CF Senior Member
You will see very soon
Old 07-10-2019, 08:48 AM
  #53
roadster65
CF Senior Member
roadster65's Avatar
Did you decide to go with the "blue" ? - found these pics, wide flares & wide wheels !
Old 07-10-2019, 09:11 AM
  #54
reno stallion
CF Senior Member
Wow I like that nice dish on the wheels. I should be able to run something close to that
Old 07-10-2019, 09:56 AM
  #55
reno stallion
CF Senior Member
[QUOTE=roadster65;1599728932]Did you decide to go with the "blue" ?
Old 07-10-2019, 10:05 AM
  #56
SonnyAK
CF Senior Member
SonnyAK's Avatar
That's a great color!
SonnyAK is offline
reno stallion (07-10-2019)
Old 07-10-2019, 11:05 AM
  #57
Dad's '66 427
CF Senior Member
Dad's '66 427's Avatar
Dayum….. that looks good.....
Dad's '66 427 is online now
Old 07-10-2019, 03:36 PM
  #58
roadster65
CF Senior Member
roadster65's Avatar
That's a very nice hue of Blue, Reno …. hmmm; the possibilities !
This is the paint that Pat put down on his car (PTJSK) …straight out of the "gun"
https://www.corvetteforum.com/forums...e-63-a-26.html
and here's another style with the big flares and the big wheels ….. great stance; one of my favourites ..
Old 07-10-2019, 03:56 PM
  #59
reno stallion
CF Senior Member
I really wanted to do it in single stage urethane for a more period correct sheen but could not get it that way. At least not in California and for some reason Porsche only has the formula in base coat clear. CRAP. I do still like it though. But haven't seen it in person yet
Old 07-10-2019, 04:05 PM
  #60
roadster65
CF Senior Member
roadster65's Avatar
The sheen on that paint looks really good, great colour choice, offset with black or chrome/polished alloy; either way will look sensational - GV
The following 2 users liked this post by roadster65:
mfain (07-11-2019), reno stallion (07-10-2019)
Quick Reply: [C2] race+street 66 build
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
