[C2] 65 Spare Tire Carrier
Old 07-07-2019, 10:24 PM
99Silverbullet
CF Senior Member
99Silverbullet's Avatar
CI 8 & 9 Veteran
St. Jude Donor '07-'08
Default 65 Spare Tire Carrier
Was it painted or left bare? If painted what color black? Thanks
99Silverbullet is offline
Old 07-07-2019, 10:29 PM
Frankie the Fink
CF Senior Member
Support Corvetteforum!
Frankie the Fink's Avatar
Received 4,026 Likes on 3,091 Posts
In 63 they were bare fiberglass. Only the metal reinforcing rods were painted ó black.
Canít say if the later ones were the same. But I believe so.
Frankie the Fink is offline
Old 07-07-2019, 10:54 PM
99Silverbullet
CF Senior Member
CI 8 & 9 Veteran
Yep want to know what the 65 year model was. Thanks
Old 07-08-2019, 12:24 AM
65 Pro Vette
CF Senior Member
65 Pro Vette's Avatar
65 was all natural except for the steel V bar, which was semi-flat black.
65 Pro Vette is offline
Old 07-08-2019, 12:34 AM
99Silverbullet
CF Senior Member
CI 8 & 9 Veteran
Ok thank you
Old 07-08-2019, 11:58 AM
BrotherVette
CF Member
BrotherVette's Avatar
Here’s mine
BrotherVette is offline
Old 07-08-2019, 10:59 PM
GUSTO14
CF Senior Member
GUSTO14's Avatar
The '66 looks to be all natural fiberglass as well, but a darker shade of gray/black fiberglass than the '63 & '64.
Good luck... GUSTO
GUSTO14 is offline
Old 07-08-2019, 11:27 PM
Sullyvette
CF Senior Member
Sullyvette's Avatar
Sweet Jesus Gusto, that's one incredibly clean underside. Ever drive it? LOL
Sullyvette is offline
Old 07-09-2019, 07:48 AM
GUSTO14
CF Senior Member
GUSTO14's Avatar
I do believe it gets driven, a bit, unfortunately not by me...
It was listed back in December 2018 on BAT where it was bid to $100,000 but didn't reach reserve. It is such a great looking car that I saved some of the pictures for reference purposes. It's an L72, 4-speed out of Yorba Linda, California and was refurbished in 2008.
GUSTO
GUSTO14 is offline
65 fi (07-14-2019)
Old 07-11-2019, 03:53 PM
99Silverbullet
CF Senior Member
CI 8 & 9 Veteran
After taking my off the shelf and taking it apart, notice the upper tub had damage where the lid sits. Thought i could reglass that area/patch it but decided to buy a new one from a vendor.
I received the new one yesterday....Why doesn't these repops come with the holes already drilled out? Is this how the factory did it, just put it up in place and screwed it thru the fiberglass?
Old 07-11-2019, 05:06 PM
Yellow6t7
CF Senior Member
Best part about the repos is that a radial spare tire fits in them.
Yellow6t7 is online now
Old 07-11-2019, 07:36 PM
BrotherVette
CF Member
This radial spare reportedly fits in the OE tub.
Old 07-11-2019, 09:41 PM
99Silverbullet
CF Senior Member
CI 8 & 9 Veteran
Im running 17” wheels, so my “real” spare wont fit, but ive got a stock rim and tire ill be putting in the carrier
Old 07-13-2019, 09:26 PM
99Silverbullet
CF Senior Member
CI 8 & 9 Veteran
what was the purpose of this part of the v-bar?
Old 07-14-2019, 12:53 AM
Dave Tracy
CF Senior Member
You put the jack handle into it to let the tire out and to close it up. The bolt holding the the bottom lid is loosened, the bottom is lifted up and the bolt is disengaged from the lid. I just worked on mine today. It was covered with undercoating. I think it was done by the dealership. WHAT A MESS!
Dave Tracy is offline
Old 07-14-2019, 07:15 AM
65GGvert
CF Senior Member
65GGvert's Avatar
Received 1,177 Likes on 1,033 Posts
That's the receiver for the trailer hitch bar. Don't do it, it was a joke. Don't do it. Like Dave Tracy said, it's for lowering and lifting the spare with the jack handle/lug wrench.
65GGvert is online now
Old 07-14-2019, 07:21 AM
Frankie the Fink
CF Senior Member
Its explained (and illustrated) on the jacking instruction placard on the underside of the jack storage compartment lid...
Old 07-14-2019, 09:48 AM
99Silverbullet
CF Senior Member
CI 8 & 9 Veteran
Yep same here, either a light coat of undercoat or someone sprayed it with flat black paint. I was able to get some of it off but still looks like crap. Going to try and work on it some more, Might just repaint it before I put the new v bar on.
Old 07-14-2019, 10:53 AM
GUSTO14
CF Senior Member
GUSTO14's Avatar
Patrick, if it is undercoat, some mineral spirits or Naptha should remove it. If they don't, it's very likely some type of paint and you can use normal paint stripper to remove it.
Good luck... GUSTO
GUSTO14 is offline
Old 07-14-2019, 11:09 AM
99Silverbullet
CF Senior Member
CI 8 & 9 Veteran
Good luck... GUSTO
Hey Gusto, I was thinking of trying the same thing. Iím about to head to the store now as thatís the one thing I donít have in my paint cabinet.
Id rather try to keep it correct than paint over it.
I thought those rivets would be a pain to remove but I literally took a tiny chisel and knocked the heads off with no damage.
Thanks!
Quick Reply: [C2] 65 Spare Tire Carrier
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
