1964 Stalls
Old 07-09-2019, 06:42 PM
Rob64
Junior Member
Default 1964 Stalls
Fellow members, Thanks for letting me join your group. I have a 64 automatic, completely stock as original. When I come to a stop light the engine idles uneven and then all of a sudden stalls. It starts right up again and runs perfect while Iím driving. It happens when the engine is warmed up. It is not over heating. Temp perfect at 180 degrees. Can anyone help?
Rob64 is offline
Old 07-09-2019, 07:12 PM
2009stanger
CF Member
2009stanger's Avatar
Have you checked your slow idle screw on your carburetor? Iíve had mine set too low and it would stall out. I believe that if you turn it clockwise it will increase your rpmís when you are idling.
2009stanger is offline
Old 07-09-2019, 07:13 PM
CF Senior Member
856666's Avatar
Hi Rob,
Welcome to the forum
I would check for a vacuum leak - hoses, or carb base gasket
Phil
856666 is offline
Old 07-09-2019, 07:38 PM
DansYellow66
CF Senior Member
DansYellow66's Avatar
What have you done on the car to date in an effort to fix it?
DansYellow66 is offline
Old 07-09-2019, 08:04 PM
Rob64
Junior Member
There is a vacuum hose going into the power brake booster could this do it? I can check this and the other vacuum hoses too. Thanks
Rob64 is offline
Old 07-09-2019, 08:05 PM
Rob64
Junior Member
I’ve had a new carb installed with new gaskets of course. Professionally done by corvette restorer. I don’t hear a gasket leak. I think it may be electrical because it stalls but more like shutting off. Seems like a connection? I’ve changed the coil.
Rob64 is offline
Old 07-09-2019, 10:27 PM
wolfman64
CF Senior Member
Support Corvetteforum!
wolfman64's Avatar
Originally Posted by Rob64 View Post
Iíve had a new carb installed with new gaskets of course. Professionally done by corvette restorer. I donít hear a gasket leak. I think it may be electrical because it stalls but more like shutting off. Seems like a connection? Iíve changed the coil.
Try disconnecting the wiring harness block at the firewall...Clean both sides and reconnect...
wolfman64 is offline
Old 07-09-2019, 10:32 PM
wolfman64
CF Senior Member
wolfman64's Avatar
Old 07-10-2019, 07:35 AM
Frankie the Fink
CF Senior Member
Frankie the Fink's Avatar
Received 4,026 Likes on 3,091 Posts
I don't think its electrical, when the bulkhead connector is an issue there is usually a dramatic loss of power...
It does sound like a vacuum leak - the first thing is to snug down the carb mounting bolts and check all rubber hoses (PCV, vacuum advance, brake booster if there is one, etc.). Wouldn't hurt to put a vacuum gauge on the car and post what you see here (if you can get it to idle)..
Frankie the Fink is offline
Old 07-10-2019, 08:24 AM
Railroadman
CF Senior Member
Railroadman's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-Ď19
A few questions - did it do this BEFORE you put the new carb on, or only afterwards? What other changes or adjustments did you make just before it started? And last, does it do this EVERY time, or just randomly?
Railroadman is offline
Old 07-10-2019, 10:34 AM
SWCDuke
CF Senior Member
Connect a test tach/dwell meter and vacuum gage to the engine. (I am assuming you have this equipment and know how to connect it.) Adjust dwell if required, and test the VAC with a vacuum pump to determine the start and stop points. Set initial timing at 8- 10. Also, report the ID data on the VAC mounting bracket.
Once any found problems above are solved, perform the idle speed mixture/speed adjustment procedure in your 1963 Corvette Shop manual. This must be done in DRIVE, so set the parking brake firmly and double chock at least one wheel. Target idle speed in Drive is 450 to 500 assuming an OE cam, however, if it has a higher overlap aftermarket cam higher idle speed will likely be required and you may not be able to achieve a smooth idle. High overlap cams and an automatic transmission are a bad combination.
Report your final idle speed and vacuum readings.
If the carb is an AFB the initial idle mixture screw setting is 1.5 turns out from the seat. lf a WCFB, consult the shop manual.
Duke
SWCDuke is offline
Old 07-10-2019, 10:06 PM
wolfman64
CF Senior Member
wolfman64's Avatar
Following the electrical path...Did you change the ballast resistor when you changed the coil?...I have recollection of a bad ballast resistor being the source of an intermittent stalling issue I had on my '64 327/365 many years ago.
Wolf
Old 07-11-2019, 10:43 PM
Rob64
Junior Member
Thanks for all the advice. I thought it best to have the restorer take the car to the shop. I’ll report back results when I get the 64 back.
To to answer some of the questions, the car ran strong with no stalling last fall. This spring also ran strong until I took it on an 1 1/2 hr drive then the stalling started. It’s not intermittent it happens all the time when in drive. I haven’t touched the carb since it was repaired. All hoses seem ok. The vacuum hose from break booster is a bit loose. I didn’t replace the ballast resistor. It could be anything that’s why I’m have the mechanic check it out. He only works on old vettes.
Stay tuned and thanks for the help.
Rob64 is offline
Old 07-11-2019, 11:30 PM
Railroadman
CF Senior Member
Did you perhaps buy crap gas on that 1 1/2 hour cruise?
Dan Hampton (07-12-2019)
Quick Reply: 1964 Stalls
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
