1960 Vette: 245 HP vs. 270 HP
Greetings from Texas. I have a 1960 Corvette (black with silver coves) with a numbers matching 283 engine with 2 four-barrel carbs and 245 HP. Can anyone tell me the differences in a 1960 Corvette with:
1. 283 / 2x4 barrel carbs with 245 HP
2. 283 / 2x4 barrel carbs with 270 HP?
I have heard that the differences include a different cam and a different radiator. Is this accurate? Are there any other differences that you may know about?
I'm planning to have the the motor in my Corvette rebuilt and I am considering making it a 270 HP Car. Any wisdom / insights would be greatly appreciated.
Received 6,529 Likes
C2 of Year Finalist (track prepared) 2019
The tach face for the 270 HP engine has a higher redline.
The generator pulley is likely larger on the 270 engine.
Edit: The above statement is incorrect. 270 HP and 245 HP engines both use 1102043 generators with 3-5/8" offset pulley
The carburetors are almost certainly calibrated differently.
If you install the correct "top tank radiator", I believe you have to also replace the radiator support.
First and foremost the 270hp cars have solid lifters and the legendary Duntov 097 camshaft.
The carbs are set up for the more aggressive camshaft characteristics.
40+ years ago, I talked at length with Noland Adams about the issues with the "new" aluminum radiator and how GM dealt with the issues and shortages of them.
Received 1,843 Likes
There was a change in hoods during the 1960 model year. Here's a commonly posted pic. Only the later hoods had the clearance for the top tank and the required different radiator support.
The current '58 - '60 judging guide sez this about the re-designed hood:
"This hood was also used for most low horsepower 1960 brass radiator equipped cars."
So the hood is essential for cars with top tank radiators but was also used on brass radiator cars.
As to the wisdom of "building" a 270hp car.....
I had an original 270hp car and they are a hoot to drive, and the solid lifter sound is unmistakable.
Would I go to the trouble to try to build one, cloned from an original 245hp engine. No. It would be expensive, they require a bit more maintenance and, depending on what the OP means by "numbers matching", if there is a stamp pad engine suffix, it won't be fooling anybody.
There is nothing wrong with tooling around in an original 245hp car with dual quads,
In 41 years of maintaining my '60 290 HP car, I bet I've adjusted the valve lash at most three times. The last time, in 2013, was because I had R&R-ed one head and there was simply no choice but to adjust the lash.
The amount of maintenance my '60 solid lifter engine requires is on par with that required by the hydraulic lifter engine in my '63.
Don’t really want to debate it.
Still, my opinion for the OP is to restore the car to factory 245hp specs.
PS. I'd change the cam to the 270. It'll make a whole different driving experience over what you have now. Not a whole lot of power increase, just different feel. Enjoy the feel and sound of a Corvette instead of a Bel Air.
I wouldn't bet it would be necessary to do anything to your carburetors to make it work with the different camshaft. Bump the initial timing up 4-5 degrees.
OLDED (04-14-2020)
This looks to be a case of the factory simply using up left over '59 hood stock opportunistically on cars with brass radiators.
To the O.P. - If you're wanting to create the look of the 270HP car, at a minimum, you'll need a top tank rad. and core support and possibly a hood. You may want to price that rad.at DeWitt's. The price alone may scare you. The 270HP engine is a sweet driver. Here's a pic. of mine. I've had it for 46 years and it was my daily driver for the fist 10 years. It never leaked a drop, even in the rainy Pacific Northwest and being parked outside. Only adjusted the lifters once in those 10 years. Then I did a complete body off restoration and it's lived a charmed life ever since.
frankturbo (04-06-2020)
