[C2] 67 Voltage regulator capacitor repair?
There's a capacitor in a metal bracket attached to the voltage regulator on my '67 small block car . This looks like in the photo below.
I somehow broke the black wire that connects the rcapacitor to the regulator, right where it goes into the capacitor, so I can't splice the wire to fix it.
My questions are:
Photo credit goes to Leif Anderson - I snipped this picture from one of his 2019 hposts!
Thanks,
My questions are:
- What's the purpose of this capacitor? Has it something to do with reducing radio interference? My car has the stock AM/FM radio.
- Is there any danger in running the car without this capacitor hooked up?
- How do I fix the broken wire? Is there a way to reattach it to the capacitor?
- Is this an easily found part at NAPA or similar? Or will I need to order one from a Corvette supplier?
Thanks,
You can buy reproductions (not at NAPA), it won't be exactly like the original:
https://www.ecklerscorvette.com/corv...All%20Products
After 60 years its not doing anything anyway but it USED to serve for radio AM band noise suppression; there are 10,000 of these cars running around with non-functional capacitors that don't even know it - won't hurt a thing. You can take some clear epoxy and tack that lead back onto the capacitor just for looks. Some will tell you if the capacitor is shorted putting the lead back in any fashion can be a problem if its shorted. Trust me, capacitors almost never short, nearly always "open", if shorted, you'd know before now.
If it worries you, check the resistance from the lead to the case with an ohmmeter on a low scale before re-installing. It will read infinity....
Mr Fufu (10-28-2020)
Received 2,130 Likes
2015 C2 of the Year Finalist
Dan
Folks also think the points in a “vibrating points” regulator are either connected or disconnected on some low duty cycle when they can actually “vibrate” 120 times a second.
Thanks Frankie and Dan!
Glad to hear the capacitor is (mostly) now ornamental. I'll glue the lead back on with epoxy and carry on!
Cheers,
Alex
Cheers,
Alex
Apple slice restoration tool
I epoxied the broken wire on my radio suppression capacitor last night.
I rigged up an old apple slice to hold the wire in place while the glue set. Worked like a charm!
