Welp. My seemingly worst case scenario happened. I’ve wanted to replace the radiator, heater core, etc hoses since I got my 66 with correct GM stamped ones. I was worried I’d break the heater core or have one I couldn’t get to stop leaking so I took it to a mechanic I trust and weaved used fir our personal cars for years. He’s not a Corvette mechanic but is a great mechanic. He just called and said they broke the heater core. How difficult is it to replace and where is the best place to source a quality one so it never has to be done again? Thanks in advance.
I do not believe that the Harrison Heater Core is produced any longer . Most are sold by the Corvette Parts Distributors and are made in Mexico. I had my 65 Harrison Core repaired by a local radiator Company. While it was gone for repair I purchased one (Mexico) from Zip Corvette Parts. It worked well.....but I had it tested prior to installing it....
And I agree, It is not one of those jobs you want to do twice!!!! Maybe you can find a recored Harrison (AND TESTED) on Ebay.....
My original had a leak and i took it to the local radiator shop. They tested it and it was beyond repair. I bought one from Corvette Central.Good build, they will tell you they are made in Mexico but Corvette Central was involved with the design and quality control.
Thanks for the info everyone. I’ve read conflicting things about how difficult it is to replace the core. Is it basically taking the nuts off the firewall then removing the glove box?
Send me a PM with your email address and I’ll send you a step-by-step set of instructions. It really isn’t hard to change the core, just takes a little patience. Mark
The elephant in the room is the mechanic, regardless of skill level, if you twist on the hoses you can snap the nipple connection to the core and its a guaranteed leak, which I suspect is what happened. Especially if they were connected with original Corbin clamps; they can be a PITA to remove.
So, do the job yourself or maybe you'll get lucky with a farmed-out installation. If your guy doesn't have a set of swivel-jaw Corbin clamp pliers he should leave things alone:
Be sure to take your new one to a radiator shop and have it tested. You don't want to do the job twice. The brand new one I purchased had a leak right out of the box, but based on advice I read here, I took it to get tested prior to installing.
When I removed my original heater core it had a leak somewhere in the tubes. I checked and they can be re-cored but you have to find a shop that still does that work. I believe that all the new heater cores you see come from one manufacturer and they are made in Mexico. So I looked for a supplier which had a good return policy in case there was a problem. I ended up buying from an online store. The first heater core I received had one of the inlet tubes so far out of whack I couldn't even get the steel plate to go over both tubes. Called and had a return label sent and they sent another heater core right away. The tubes were soldered in correctly on that one but it failed a pressure test. Very small pinhole on one of the end tanks. Rather than sending that one back (and risking them sending my first one to me again) I just soldered the pinhole, re-tested it, and put it in the car. No leaks so far but I did keep my old Harrison and will recore it if this one fails someday.
Several threads have indicated that the core should be checked PRIOR to placement. I had a replacement that leaked out of the box also. I have factory air to my job was a little more involved but doable.
you can buy them at your local auto parts store. its the same one your pay more from a resto parts house.
I bought one from a big chain local store and it was not the same and did not fit right. I wound up ordering one from a Corvette only big name place and even though it cost more it fit perfectly. Compare to your old one closely and oh yeah, not a fun job.
