Engine swap
Old Apr 28, 2021 | 03:20 PM
Fatdaddy's Avatar
Fatdaddy
Default Engine swap
I have a 62 that I’m going to install a blueprint 383 stroker engine in. What I would like to do is get away from my current bellhousing that requires you to bolt the starter to and be able to bolt it to the block. Can anybody tell me which bellhousing I would need to go to? Thx
Old Apr 28, 2021 | 07:45 PM
R66's Avatar
R66
I am thinking DZAuto is the man you want to talk to, but I don't think any change is needed. With the same generation block, you have the same fitup.
Old Apr 28, 2021 | 08:10 PM
Vette5311's Avatar
Vette5311
You can use a regular bell housing but it must match your flywheel size. 10 and 1/2 or 11. AND of course a different block mounted starter matching flywheel diameter also.
Old Apr 28, 2021 | 08:35 PM
Fatdaddy's Avatar
Fatdaddy
yeah I’ve been talking to him this evening,he certainly knows more about this than I do. Thx Mike
Old Apr 28, 2021 | 08:37 PM
Fatdaddy's Avatar
Fatdaddy
somebody said something about the way the clutch rods and assembly fits that there could be some issues.Thx Mike
Old Apr 28, 2021 | 08:40 PM
Vette5311's Avatar
Vette5311
Yes you need a Corvette clutch fork because it is different also, but it fits either bell housing.
Old Apr 28, 2021 | 08:44 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
If you are putting a 383 in it, then seriously consider a scatter shield then use a mini starter.
Old Apr 28, 2021 | 08:55 PM
Fatdaddy's Avatar
Fatdaddy
probably not a bad idea
Old Apr 30, 2021 | 10:08 AM
40ZR1's Avatar
40ZR1
If that's a Blueprint engine you will need a new flywheel. The one piece rear oil seal is larger.
Old Apr 30, 2021 | 11:21 AM
Fatdaddy's Avatar
Fatdaddy
have you used one of their engines?
Old May 1, 2021 | 07:50 AM
40ZR1's Avatar
40ZR1
Yes, have one in my '57 Chevy convertible. Make sure you have a good dist gasket and down tight or you'll be chasing a mysterious oil leak! Ask me how I know, after pulling the intake thinking it's the china wall gasket leaking!
CJ
Old May 1, 2021 | 07:56 AM
Fatdaddy's Avatar
Fatdaddy
CJ
thanks for the info. What flywheel did you use ? Also we’re you satisfied with your engine? Thx Mike
To Engine swap
