1962 327 4 speed manual - maroon red
Not interested in buying, BUT.............Friend showed me his garaged matching numbers Corvette this am.........Question.......what would be the value on a 327 4 barrel 4 speed Maroon Red ( not original paint - but matched it) 1962 Corvette, all stock, with 96K miles that was put away running and in good shape? AND.....High side ballpark cost to just get it running again as a safe driver? No reason given for the storage, just driving other cars.. .....Photos below. I think he is in his 70s and attached to the car, thus the storage........
abiazis (11-28-2021)
The following 2 users liked this post by kenba:
abiazis (11-28-2021),
Dan Hampton (11-28-2021)
2023 C1 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared))
2019 C1 of Year Finalist (track prepared)
I think this is closer to accurate, with a current retail on this car around 60. Show me another numbers matching two top 340hp '62 for 40. I've searched and there's currently nothing even close.
UNLESS the frame is rusty. Front hood gap concerns me a little; check for prior body damage. Of course you should anyway. Is the soft top there and decent? Has the engine been started in recent years, or is it at least free? Brakes still holding pressure?
Are you good with old cars? If you are, getting this car back on the road should be very cheap. Change all the fluids and remove the fuel level sending unit to check for rust in the tank, but if it's in heated storage I doubt that there will be. Maybe change the brake hoses (good brakes are by far the most important part of prepping an old car). But 10 years isn't that long depending on the storage environment.
Any old Corvette should be looked at by a knowledgeable person before purchase. Unless you're comfortable with your level of expertise, hire an expert. But do it soon, because someone's going to snap this up for 40.
Received 1,728 Likes
2018 C1 of Year Finalist
My concern would be all the detritus being jammed next to the car. How many non-removal scratches might have been created with what appears to be a lot of random jamming of metal baskets and plywood against the side of the car. Good paint always brings a premium, given the cost of a respray.
To answer the OP's question about getting it running, again, I would say the fuel system is probably a mess after ten years. How much hygroscopic action has taken place within the brake cylinders, potentially creating leaks over that period of time?
Having said that, this looks like a 340 hp car, and the chrome, especially on the rear, looks pretty nice from what I can tell.
I have no opinion on price.
abiazis (09-25-2022)
PS. The hood gap in front is pretty typical of a C1
If you decide you don't want it, PM me. I'll pay him $40K and give you $1,000 finders fee and pick it up.
The following 3 users liked this post by 65GGvert:
soft top clamps are present on the deck lid. True, some solid axle Corvettes came with a hood gap like that, but that looks like a wider gap than it should be. Pictures can be deceiving, but would be an area to inspect closely.
vettsplit 63 (11-29-2021)
BAT Auction Results 1962 Corvettes
Here's a link to 53 completed auctions on Bring A Trailer for 1962 Corvettes. They span from 2 days ago to back to 2016. There were 27 auction so far in 2021. That should give you an idea of the market:
https://bringatrailer.com/auctions/r...=1962+corvette
You have to scroll down to the Corvette section.
Thomas
Thomas
The following 3 users liked this post by BB767:
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Thats a steel buy it!
Almost Retired
I would like to hear why it has not moved in ten years IF it was running ok? I I would also like to know why he doesn't get it running and get more money for it? If it sounds too good to be true it usually is. 60 to 70 for a car you can't hear run, drive, know if drive train needs work or see under the car is a crap sloot at best. You could easily have 100,000 grand before you are done. Running and drivable 60 to 70 maybe, but I doubt it.
