C2 L76 engine
Old Jan 9, 2022 | 07:21 PM
Timz06's Avatar
Timz06
Default C2 L76 engine
I have a 64 with the 365 hp engine. Mine is very grumpy in traffic and doesn't like starts and stops. Is that normal or do i have a tuning or other issue? Thanks, Tim
Old Jan 9, 2022 | 07:42 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
but when you get it above 1500 rpm it's like waking up a monster?
Old Jan 9, 2022 | 07:47 PM
Timz06's Avatar
Timz06
It really starts pulling hard about 4500. I was thinking if it would be a good idea to take out this original engine and get a 383 to drive around in, keeping the original intact. Just beer drinking thinking!
Tim
Old Jan 9, 2022 | 07:49 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
The correct rear end is likely the answer to your problem. What ratio do you have? You really need a 3.70 or a 4.11 if you have a close ratio trans. If you want a more highway friendly (80 mph for two hours or more) then a 3.36 rear end ratio with a wide ratio trans that has a lower 1st gear will be better for take off and more pleasant for long freeway type trips.
Old Jan 9, 2022 | 07:54 PM
Timz06's Avatar
Timz06
That makes sense. I am not sure what rear i have but I did some speed checks a couple of years ago and it seems to a 3:08. It is very hard to get the car going.
It is the original engine, 'rebuilt to original specs' as they said when i bought it but not sure what is really in there of course. I have had this car for about 7 years.
Thanks,
Tim
Old Jan 9, 2022 | 07:57 PM
C2CorvetteBob's Avatar
C2CorvetteBob
Swapping the L76 solid lifter cam for the L79 hydraulic lifter cam would make the car a lot easier to drive at lower speeds and in traffic. For that matter there are lots of cams that would have more low end torque than the L76 cam. Easier than an engine swap.
Old Jan 9, 2022 | 07:59 PM
Nowhere Man
put the 4:11s or 3:70 like GM said too and it will be better.
Old Jan 9, 2022 | 08:01 PM
Timz06's Avatar
Timz06
makes sense about the gearing and a simple solution, just need to find someone that can work on these old cars, gear change is one thing i have never done!
Old Jan 9, 2022 | 08:04 PM
Nowhere Man
you swap the pumpkin., but I would make sure that you have first
Old Jan 9, 2022 | 08:12 PM
68hemi's Avatar
68hemi
Check with your local Corvette club. There are plenty of old members that likely aren’t working on them themselves so they should know where to direct you for a GOOD person to do it for you.
Old Jan 9, 2022 | 08:22 PM
Timz06's Avatar
Timz06
i guess you are right not too many young C2 owners out there! I have just never paid anyone to work on a car that wasn't under warranty but i need to start. Thanks, Tim
Old Jan 9, 2022 | 09:51 PM
FLYNAVY30's Avatar
FLYNAVY30
Hey Tim, I also have '64 L76....Id start by verifying your rear gear ratio in addition to verifying your timing. These motors are fantastic, but can be real dogs if the timing isn't set up correctly. For what its worth, mine is bone stock with the addition of long tube headers and pulls hard above 2000 RPM.
Old Jan 9, 2022 | 10:33 PM
Timz06's Avatar
Timz06
thanks for the comments guys. I did get a timing light and i think it is ok. Most likely the gearing i'll get it out and figure it out when it stops raining here in GA.. It's just a bear to get going. When i bought the car it was a garage queen. In the first few months i owned it i fixed a bunch of mecanical issues like clutch, fuel pump, fuel sender, and an interesting issue where the water pump gasket was blowing out, turns out the previous owner was trying to put original parts on it and put a new water pump but someone had left the bolts from an aftermarket one that bottomed out, blew several gaskets before i figured it out by luck when i went to put on an original fuel pump that the previous owner provided and the bolts were not right, as the flanges were different sizes. Also rebuilt the carb wrong jets and metering rods were installed.
Old Jan 10, 2022 | 12:52 AM
alblosser's Avatar
alblosser
I had a 64 L76, and currently have a 65 L76, They work best with a 3.70.or 4.11 rear end. I have a 3.55 in my 65 and it is OK also, but I wouldn't go any higher. A blueprint 383 with any rear end would be awesome. The torque is amazing right out of the hole and the roller cam simplifies maintenance. Plus it works on pump gas. If I were younger I would do it in a heart beat. Tremec TKX also. It was built to drive so do it. You only live once. (by the way i'm almost 77)
Old Jan 10, 2022 | 07:25 AM
Rob_64-365's Avatar
Rob_64-365
I have a 64 L76, that had a 67 pig with a non posi 3:08 rear end in it, I took it in & had a 3:70 posi put in which really woke the car up, but in doing so raised my highway rpms, as it obviously would, so now I'm thinking a 5 speed trans would really be what that logical next step is as I look at the car as a toy to have fun in, not a historical preservation exercise that needs museum curator approval to do as I please.
Old Jan 10, 2022 | 09:08 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Tim,
I have a 65 L-76 with 76,000 original miles. It has a Holley double pumper/dual feed replacement carb, installed and rebuilt and tuned prior to my ownership, and tube headers.
I pump the pedal twice and it roars to life consistently. I live in Fla so no warm up required although I let it run a few before taking off.
Mine idles smoothly at 900 rpms and has no issues in local traffic at all. It does come on as you wind her out. I would do as suggested above.
I have the factory installed 3:70 rear and the 4 speed trans.
Gearing and tuning may be the solution.
HTH,
Marshal
Old Jan 10, 2022 | 09:16 AM
Patrick03's Avatar
Patrick03
Drifting<br><img src="/forums/images/ranks/2k-3k.gif" border="0">
Here's a good thread I referenced when I set the timing on my '64 L76:
https://www.corvetteforum.com/forums...be-set-at.html
Patrick
To C2 L76 engine
Old Jan 10, 2022 | 09:03 PM
Vega$Vette's Avatar
Vega$Vette
I suggest you learn how to drive it instead of changing stuff.
just sayin
Old Jan 10, 2022 | 09:36 PM
68hemi's Avatar
68hemi
just sayin
What kind of a remark is that? It sounds to me like it has been identified and will be confirmed that the car has WAY to high of a rear end ratio. This will of course make the car hard to take off from a dead stop and has NOTHING to do with the OPs ability to drive his car.
Old Jan 10, 2022 | 10:01 PM
Vega$Vette's Avatar
Vega$Vette
I mentioned this out of no disrespect.
many guys that have engines that need to run in the higher rpm range don’t know how to drive the cars. Same as 1st Gen Camaro guys with 302s.
can not even suggest option unless the OP knows what rear end ratio he has.
