Stock Appearing BBC – 9.15 at 145.55 mph in the quarter mile!
I recently removed the TH400 clutch setup from my car and went to a torque converter. I decided not to use a trans brake and instead I am foot braking the car. First time out (8/25/2022) I managed a 9.47 at 143.96 while pulling the front tires off the ground about 5” and the engine sputtering through 1st gear. After that race I talked with Will(rklessdriver) about these two issues. He came up with some ideas right away. I shared a few videos with him and he was able to give me shock settings and carb ideas that he thought would help. I went to work making these necessary changes.
On 9/22/2022 at Pacific Raceways the first run off the trailer was a 9.22. At the launch the tires didn't come off the ground and there was no sputtering. The next 5 runs were between 9.15 and 9.18. My best 60 ft was 1.289. I had never felt a car pull this hard in first gear! The next day I emailed Will to report my results and to emphatically thank him for his help. I once again sent him a few videos and after he examined them he gave me more recommendations for shock adjustments to use the next time I go out (next season). We are very fortunate to have someone in our Corvette community like Will that is exceptionally knowledgeable and extremely helpful!!
Here is some background on the car. It's a 1967 Corvette coupe. I am still using my same stock appearing motor that includes a factory Chevrolet Tri-Power intake with (3) two barrel carbs, factory cast iron exhaust manifolds, and a full exhaust with mufflers out the back of the car. It's a 582" naturally aspirated BBC using a Chevy Bow Tie block, 4.600” bore x 4.375” stroke. I have gone through a great deal of work to have the engine compartment appear the same as it did when the car was built in 1967. I went so far as to take a current set of Dart heads and make them look like the original factory cast iron heads. Since I have the car's original 427 I was able to make patterns of the factory heads and went to work with my grinder's on the Darts.
The rear-end setup is a Mike Dyer built Tom's 1480 12-bolt conversion with 3.73 gears. Mike did all the machining to get the 12-bolt in the case as well as setting up the gears, posi, and inner axles (is there anything Mike can't do?). Tom's 3.5” halfshafts, outer axles, frame reinforcement, upper control arms, and safety loops are also being used. I modified a pair of factory trailing arms to allow for 15 x 8 wheels with a 6” backspace. Dave Ogden supplied us with the jewelry-like diff caps and the u-joint caps.
I have been running a clutch turbo 400 transmission in this car since around 2016. For those not familiar with a clutch turbo 400, the torque converter is replaced with a clutch setup. The best times with the clutch turbo 400 were a 9.63 et and a 148.14 mph. The best 60 ft was a 1.585 but all others were in the high 1.6's, 1.7's, and worse. I could never get the car to launch consistently. I either left the line slipping the heck out of the clutch or the tires just spun.
Will was able to get me a set of double adjustable Viking shocks for all 4 corners of the car. He gave me detailed suggestions on where to start settings wise and what to do based on how the car was reacting. Unfortunately my inability to have any kind of consistency when leaving the line didn't allow his suggestions to be properly put to work.
Well I was finally done with the clutch turbo 400 and contacted Neal Chance Racing Converters for some ideas. I talked to Doug and my gosh does he know his stuff! We went through all of the data from the time slips, the Racepak data acquisition, and the DynoJet. He ended up suggesting a 9” bolt-together converter with approximately 6000 rpm stall. Doug made sure to tell me to call him once I got a few runs under my belt to go over the new data. When I told him I have a DynoJet at my house and that I use the crap out of it he told me to expect as much as a 100 rwhp loss vs a manual transmission! I told him I didn't care as long as the car would go quicker and I could get some consistency out of it. I also told him about the time I had the 632 in the car with a Coan PG and lost 100 rwhp. At that time I wasn't racing the car so I removed the PG and went back to a manual trans.
I immediately went to work and took the clutch turbo 400 apart, replaced the forward drum along with it's clutches, replaced the front pump, installed new teflon seals, set up all the clearances, installed a new JW UltraBell, and then installed everything back in the car.
I put the car on the DynoJet and instantly lost approximately 70 rwhp! The car was making around 740 rwhp with the clutch turbo 400 and it dropped to 670 rwhp with the new torque converter combination. Again, I didn't care because I was convinced the car would go quicker.
I am now on a mission to get in the high 8's. I think if I can find another 30 rwhp while keeping the stock appearance and apply Will's shock recommendations I might be able to get there!
The following 16 users liked this post by 632C2:
'75 (10-01-2022),
62vetteuk (10-01-2022),
63 340HP (10-01-2022),
65air_coupe (10-01-2022),
C.T. (09-30-2022),
and 11 others liked this post.
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Sounds like a bad hot rod. We’d like to see some pics. 👍👍😎
WaikikiWayne (10-03-2022)
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Congratulations Steve! That thing is amazing...you've got it dialed in well!!!
JIM
JIM
Thanks for sharing would love to see some video runs/passes of the car, I ran a 540 pump gas (10:1) engine in a 55 Chevy best times were 10.17 @135mph with a 400 turbo trans & 4.56 rear gears,, I always felt I left a lot on the table with them rear gears & wanted to have the car scaled etc..
I commend what you achieved BIG TIME I know what it takes besides lots of $$$$, its a whole new world of trial & error & experimenting, bench racing with other racers like you have done seemed to pay off big time.
Good Luck
Chalie
Good Luck
Chalie
It was worth a minute or two to dig up a couple of your old threads for a picture of the motor. Wow! It sure does look stock, right down to keeping factory style ignition shielding and exhaust manifolds. The whole package is really impressive. What did you do to the exhaust manifolds and pipes? That's a lot of motor to hook up to stock looking exhaust.
I love how you’re laser focused on your dual mission. Looking stock yet wicked fast. I wish you were my neighbor with a dyno in his back yard. Really fun read. Thx…. Fully expect to see that sub 9 slip someday.
632C2,
That is impressive and amazing. Sounds like 8s wiil be there soon. What a milestone accomplishment, to say the least. It would be cool to see pictures and a youtube video!
Also, what are you using for rear tires?
Frickin' awesome!
Originally Posted by TAlvarez
Very impressive. Thanks for the detailed write up. Keep us posted on your future accomplishments.
Ted
Ted
Good Luck
Chalie
Good Luck
Chalie
Originally Posted by DiabolicalDave
Frickin' awesome!
vjjack04 (10-02-2022)
Dr L-88 (10-01-2022)
