I am going to use Kieth Black KB 156 or KB 157 pistons in a 327 rebuild. The KB specifications indicate that with 62 cc heads it should be 9.8 and with KB 156 pistons and 10.7 with 157 pistons.
When I input the info into one of the compression calculators I do not get those results. It is off a significant amount. Have i made an input error?
KB 156 calculation
I would keep the same compression ratio that the engine came with or you have a morphidite that you cannot say it is a 300 340 350 HP and so on.
The engine is the vette also, and modifying the engine to me is like changing the color of the car. Just my opinion. If gas is the problem then get the right gas for the compression.
