Does C2 frame design lend itself to front end shudder under certain rough road surface conditions?
The shocks on my car are the Gas-a-Just units. The shocks appear to be in good working order but don’t entirely dampen out minor road surface imperfections without front end frame shudder and/or vibration.
Might this be inherent in C2 frame design?
John
No. If all is up to snuff, springs, bushings, ball joints, idler, sway etc etc it is a nicely engineered suspension.
A convertible can have some degree of cowl shake or shudder - not unusual for a lot of convertibles especially 40 - 50 years ago. It’s probably a symptom of some degree of frame flexing on rough roads and bumps that is magnified by the mounts. But on a smooth road with suspension, tires, shocks, alignment and wheel balance up to snuff, you shouldn’t be feeling it. You may need to have your caster setting checked.
The car is a vert,yes. All front end rubber bushings, ball joints, shocks, etc., have been replaced.
There’s about 30K miles on the components at this point. .. The frame is in good overall condition. No rust issues. Body mounts haven’t been replaced.
Wondering if anyone else might have this going on with their car.
Thanks guys.
Thanks guys.
John
We need a better idea of what the shudder you describe feels like, in the steering wheel, in your torso...because torsional rigidity in the verts is not impressive if you are not accustomed to it. Cowl shake, or as the Brits prefer to say, scuttle shake is the natural state of body atop frame convertibles, think shoe box with no lid. However it reveals itself only over rough pavement.
Have you gone completely through your front end? Ball joints? Idler? Tie rod ends? Do that first.
As Dan said our beloved mid-century Convertibles can be floppy. It's the price paid for the sun burn.
Nothing untoward or unusual in handling, the overall ride is good. The shudder or vibration feels like it's coming through the foot well area and slightly through the steering wheel. This happens going over a road defect, say a small pot hole or irregular road surface.
Frame checking for any sign of a problem, all looks fine. Same with all suspension components. Perhaps that's the way it is on some verts, at least on mine. I can certainly live with it.
John, you're going to have some lateral movement of the firewall as the front wheels transmit impacts. The steering column will telegraph that movement. Certainly much of this is exacerbated by worn suspension bushings, bad shocks, weak springs, bad body mounts and in extreme cases a rotted birdcage.
Drive someone else's or let one of us drive yours.
