the wanderer
My ex-wife didn't approve..... Hence the ex part.
I went to Mecum in Glendale and fell in love with a silver 62 with red interior.
It came from the Rick Hendricks collection.
I'm in love. I figure I didn't pay too much,,,,,, just too soon
Anyway.
Driving is a white knuckle experiance.
I am going to order some radials that look like bias ply. (Not sure what size I should get)
Hoping that helps some, but guessing I may have to delve into suspension or steering box.
Being new to these, I'm hoping someone can lead me.
Kurt
I have around 10 older cars from 37 chev to newest being a 70 road runner. With Buicks, Olds, Pontiacs, and Fords thrown in. (I like everything)
But except for the 46 woody, nothing has made me white knuckle this bad.
But I love it and will try and correct without changing the originality (hopefully)
As you've already heard, and I agree completely, tires can be a helluva contributor to squirrelly (sp) steering issues, as you've already figured out.
When I picked up my 66 L72 Roadster in 2021 it had a nearly new (looking) set of Coker Goldlines on it. They really looked new and probably had no more than
5K miles on them but...the receipt for those Goldlines was dated 1994. Add in a little precipitation and the drive was hairy at best.
As Factoid mentioned, there's a ton of difference between 62 and older solid axle Vettes and anything else but starting with good tires adn
give it a little time to get accustomed to driving a car with no power steering or brakes and you'll start to feel more comfortable driving it.
Mike T - Prescott AZ
I will point out some universal basics though:
If possible, contact a local Covette club or some other C1 owner in the area and see if you can ride in another C1 to compare what you're dealing with.
1: First step is to change the tires as you are planning. The tires you have may not only be bias ply but may also be aged out. It would be interesting what the age date is on the tires you have.
here's a couple of tire links: https://www.corvetteforum.com/forums...as-plys-2.html
2: Visually inspect the rag joint, steering box, tie rod ends looking for looseness. Same for any play in the kingpins; control arm bushings.
3: Verify alignment.
Here is where things get tricky. The C1 Kingpin setup is very different from the ball joint setup you have on most of your other cars. Here's a couple of links to get you started in thinking about the alignment.
https://www.corvetteforum.com/forums...alignment.html
https://www.corvetteforum.com/forums...ent-specs.html
visually check to see if you have these alignment shims still installed on your car: https://www.corvettecentral.com/c1-5...gnment%2bshims
The trick will be to find an alignment shop that can capably adjust what you have if it needs adjustment. It may be helpful to just measure what you have for alignment settings as a baseline and post here for opinions before trying to modify the alignment outside of simple toe adjustment.
If you're lucky, tires, alignment and perhaps something easy like replacing worn tie rod ends will get you where you need to be.
Last but not least,If possible, contact a local Covette club or some other C1 owner in the area and see if you can ride in another C1 to compare what you're dealing with. This could even be a very good step to take just after you install new tires.
Hope that's a start. Good luck!
Tom
It would help you get better guidance if you could provide a clear description of what's happening.
For example, does the car tend to wander? Do you have to turn the steering wheel a lot before the front wheels notice? Is the steering effort too high? Does the steering feel "notchy" at certain points when turning the steering wheel? When you turn into a curve, do you find you suddenly get more steering than you wanted and have to back off on how much you've turned the wheel? Something else?
To your tire question, the OEM tire size was 670x15, the modern equivalent is 205/75R15. Not everyone has had pleasant experiences with some of the collector car tires available, it often seems to be hit or miss on getting a set that wants to be balanced. As mentioned above, Diamond Back is a good alternative, though they're taking modern tires and adding a white side wall to them so you lose many of the sidewall markings and of course they look nothing like a bias ply tire. 62 was the first year GM went away from the old wide white side wall tires. The original white wall width was in the 7/8" to 1" range in 62.
The 62's front suspension was developed in the late 40's for use under the 49 full size Chevrolet, so even compared to that 57 Nomad the suspension is archaic. There's no doubt that radials will help (I'm running slightly shorter and wider 215/65R15's on my 62), but if everything is tight and in good order it should go down the road straight. Like any car the things to check are alignment, tie rod ends, suspension bushings, play in the steering box and of course on a 62, king pins.
While I personally tend to gravitate toward red cars, the Sateen Silver with a red gut is a striking combination, a friend of mine has one in that combination. What engine/trans is in your 62?
Good luck and keep us posted. There are lots of knowledgeable guys on this forum and no question is too dumb. We were all first time C-1 owners with the same questions at one time or another.
I will start with tires and alignment continue from there
Someone asked what it's doing.
Basically it will drift one way, and then it takes a lot of steering input to correct, which then has me going in the other direction
then back the other way....
And no I'm not expecting new car driving.
I have 3 cars with Art Morrison chassis, and one with Detroit speed.
I will not do that to this car. It's too perfect
Might also check that the rear axle housing is solidly attached to the springs
