[C1] C1 Caster?
Old Mar 30, 2024 | 05:16 PM
'62 c-1's Avatar
'62 c-1
Default C1 Caster?
Trying with great difficulty aligning the front end of our '62. It seems that most parts outlets are "out of stock" of the '62 Frame Front Cross-member Shim. We may be making our own, are there any blueprints/specs of the front end aluminum shims? Thanks, Dan
Old Mar 30, 2024 | 08:46 PM
Leo Guggenbiller's Avatar
Leo Guggenbiller
61 C-1
Most of the big suppliers ( corvette central, zip sell them. Never seen any prints but then I never looked.
Drive em safe
Leo
Old Mar 31, 2024 | 08:19 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
There is one listed on e-bay for $25 + shipping.
Search for: 56-62 C1 Corvette Alum Front Suspension Shim Plate--GM #3736477--Exact Repro!
And a used pair for $150;GM Original C1 Corvette Ft Frame Crossmember Shims 3733477 56 57 58 59 60 61 62
Old Mar 31, 2024 | 09:17 AM
'62 c-1's Avatar
'62 c-1
Thank you both!
Old Apr 1, 2024 | 09:18 AM
dmtparker's Avatar
dmtparker
What is your time frame? I'm quite sure I have a pair of new (repro) shims, but I won't be getting back to the car for ~6 weeks.
Old Apr 1, 2024 | 09:46 AM
jerry gollnick's Avatar
jerry gollnick
I put in two shims on each side to help get some castor. This is tough, I worked a couple days to get 3 degrees. Had to "clearance" some parts.
'62 c-1's Avatar
'62 c-1
Good morning,
Thank you for your message! I'm trying to get them PDQ. I need to get the car out of the shop ASAP if not sooner!
To C1 Caster?
