[C2] Window adjustment
Old May 6, 2026 | 06:24 PM
sped1967's Avatar
sped1967
Default Window adjustment
My roll up windows are a 1/2" lower at the rear then in the front of the window. I adjusted the vent window but it did not help, so is there an adjustment to the window?
Old May 6, 2026 | 06:31 PM
66jack's Avatar
66jack
YES
In the photo the lower 'track' is the adjustment...loosen the rear screw to raise bracket then tighten..
63-67 Door Side Window Regulator Upper Track
Old May 6, 2026 | 06:45 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Make sure the lower track mount on the back edge of the door isn't broke out
Old May 6, 2026 | 11:01 PM
sped1967's Avatar
sped1967
Thank you both very much!
To Window adjustment
