Differences between 327s
After teardown the remaining rods were magnafluxed. There were two other rods that were found to be cracked, also.
Okay now for the answer. You guys have calculators with minds of their own. ;) I think you might have mixed up radius and diameter. You can either work with bearing diameter and stroke or bearing radius and crank throw radius, which is half the stroke.
For a small bearing 327 journal overlap is:
(2.30 +2.00 - 3.25)/2 = 0.525"
For a large journal 350:
(2.45 + 2.1 - 3.48)/2 = 0.535"
Now if they had built a 350 with small journals the overlap would be:
(2.30 + 2.10 - 3.48)/2 = .410"
The loss of journal overlap would have significantly reduced cranshaft stiffness, which would increase deflection and reduce durability. Thus the increase in bearing size to restore journal overlap. Excess crank flex can also beat up bearings. Back in the mid-seventies I was racing an EP TR-3 with SCCA. The engine was a 2.2 liter TR-4 - basically a souped up Massey Ferguson tractor engine - with a long stroke and a three main bearing crank. Revving to 6500 the crankshaft flexed so much and beat up the Clevite 77 bearings so bad I had to change the rod bearings every six hours of run time, which was about three race weekends.
To get a better intuitive feel sketch a couple of near equal size circles that overlap about half their radii to get a feel for journal overlap. This is what you would see if you sectioned a crank at the center of the cheek and looked at it end on.
Sorry, I can't award any junior engineer certificates tonight. :D
Duke
[Modified by SWCDuke, 11:18 PM 7/10/2003]
I thought I might have been using a broken calculator, but I kept getting your answers. Maybe some of the students were confused by the term "throw radius", which is redundant. "Throw", in itself IS a radius.; "stroke" is a diameter.
Great lesson Duke--very interesting!
Joe
so, what is an acceptable range for bearing overlap for a stout street engine? i'm sure it's like the rod length/crank stroke ratio. i assume reciprocating mass and piston speed determine the necessary value you need.
also, why are the journals for the crank and the rods not the same diameter? if you increased one, you could decrease the other, but only to a point. what are the trade offs.
we have so much to learn professor swcduke....
:flag
A crankshaft is a very complex piece of geometry. Back when the SB was designed actual crankshaft loading could be analyticaly determined, but it was difficult to analyse crankshaft stress, bending and torsional stiffness. Of course, nowadays an engineer can probably design and completely analyse a crankshaft in a few days with CAE software.
Back when the SB was designed, crankshaft dimensions were usually based on engineering intuition and "good design practice." Prototypes would be built and sent to the lab for testing. Even back in those days GM had very sophisticated labs that could test and characterize structural parts like frames, connecting rods, and crankshafts. By setting a crankshaft in a hydraulic press and loading it and measuring defections, the engineers could determine experimentally the approximate value of crankshaft bending and torsional stiffness, and again, use good design practice numbers that were developed empirically to determine what was a sufficient level of stiffness. If first articles were not sufficiently stiff, dimensions would be adjusted using experience and engineering intuition and a new prototype built and tested. This process was repeated until the specifications were met. As you can imagine, this was a long and costly process. Nowadays, with CAE software, first designs usually test out very close to specification and require little or no rework.
So there are no magic forumulas to determine journal overlap, and it's a function of other crankshaft dimensions and crankshaft material. For example, a steel crankshaft will be slightly stiffer than a cast iron crankshaft, because steel has a slightly higher modulus of elasticity than cast iron.
Bottom line is that OEM Chevrolet crankshafts are well designed and essentially indestructible in a street engine as long as they don't get oil starved. The rods through '66 are weak, so the latest rods should be used when rebuilding a small bearing engine, or aftermarket rods used if you want an absolutely bulletproof street high performance engine.
As far as bearing diameters are concerned, rod bearings are typically less in diameter than the mains. In some engines, rod bearings tend to not last as long as mains, which would indicate that rod bearings should be larger, but slightly smaller rod bearings than mains seems to be common design practice. If anything, on a give design, the rod bearing sizes should be increased rather than reducing the main bearing size, however, a modern engine given OEM oil changes will rarely wear out the bearings. The first wear item is usually the valve guides, followed by cylinder wall wear at the top of the bores.
Duke
Crank throw is actually the distance that the C/L of any rod journal is offset from the C/L of the main journals. This distance is the radius of the "orbits" that the rod journals make around the main journals.
Can you shed some light on whether critical values for journal overlap would change based on whether the crank is flat or cruciform?
Joe
The SB, inline six, and Chevy II four of the sixties all shared the same 2.30"/2.00" journals, but overlap varied according to stroke. The 140 Vega probably had the least overlap due to its 3.625" stroke, but since the crank was loaded with only four cylinders, instead of eight, the less jounal overlap gave adequate stiffness.
I can't say whether crankshaft configuration - flat, cruciform, or a six throw inline six crankshaft requires more or less overlap than the other, but you can assume that as the number of cylinders increases and/or cylinder size increases, the greater loading requires increase crankshaft stiffness, which is why the big block has larger journals, and that probably explains why the Vega crank was designed with the small journals eventhough it had a longer stroke than the 350 SB.
Duke
A V8, with 5 mains and 4 impulses per rev, probably needs more overlap. I'm just speculating that the flat crank, with its evenly spaced impulses , or one every 90* of crank rotation, MIGHT need less overlap than the cruciform, which has unevenly spaced impulses.
Joe
Compare the Vega crank to the 350 SB crank. The Vega crank has a longer throw and less journal overlap, but its only being loaded by four 30 HP cylinders rather than eight 40 HP cylinders, so a less stiff crank is okay.
Duke
With a 5.7" rod the 302 r/l is 0.265, and a 350 is 0.305. With a 6.0" rod a 350's r/l is 0.29. Though some claim more power with a six inch rod the evidence is not conclusive and any power difference is probably within the range of average run to run variation, so it's a real stretch to draw a definitive conclusion.
Duke
however, i've also read that a shorter rod increases piston speed, which serves to increase the cylinders air pumping capability. but ultimately, the side loading of the piston on the power stroke would decrease durabilty.
i wish i were an engine builder (with lots of money).
In discussions of rod ratio, proponents of long rods usually say the the pistons "dwells" near TDC longer than with short ratios. This is correct, and why I said that longer rods come closer to the ideal of combustion at constant volume, but, again, within the range of typical r/l ratio, the differences in fuel efficiency or torque/power are within the range of random test error, and the whole argument about rod ratio is academic hair splitting.
I have a lot of respect for the late Smokey Yunick. He was a true self taught engineer and probably read more IC engine text books and technical papers than I ever have, but in the case of rod ratios I think he was stretching a theoretical argument to extreme.
The ideal r/l ratio is zero, which can be obtained with an infinitely long rod. Of course the engine will also be infinitely tall and infinitely heavy. ;)
Duke
Duke ..
From what I can remember I believe the machinist who did the magnafluxing found those other two rods to be cracked in the bolt head area, as you described earlier in this thread. The crankshaft was in good condition too. I didn't notice any discoloration or other signs of damage to suggest an imminent bearing failure. I had planned on reusing that crankshaft, after having it checked out by the machinist, but it didn't come to that. In the interim while getting parts together for the rebuild a buddy gave me the forged crank out of his 365 hp engine, which checked out perfect. That crank and 5 of the old rods, along with 3 new ones, were reinstalled in the replacement engine block. The machinist felt there would be no problem going this route so that's what was done.
I'm thinking of pulling the engine soon and refreshing the internals because I'm pretty sure the cam and lifters are toast. I think I'll change out those connecting rods too, just for "insurance" ..
The only seemingly reason I can think of as to why the original rod failure occurred was because the guy who owned my car before me just simply beat the HOLY BEJESUS out of that engine .. ! .. :smash:
