Are you having problems running high compression on pump gas?
I'm thinking of putting my old 11:1 comp small block back in my '64. It's been sitting since '81, so I thought I'd freshen it up and add a new solid cam. Is anyone having problems running pump gas on their engines?
Re: Are you having problems running high compression on pump gas? (Kid_Again)
As Kid says it depends on your timing. It also depends on your cam specs and you dont mention what youre running. For a given compression ratio more overlap has the effect of making the engine more tolerant of todays gas.
No. I run Amoco Ultimate (92 or 93) in my 70 350/350 with stock timing. No problems, but I don't stand on it very often. It will not tolerate 87 at all. CR is 11:1.
St. Jude Donor '14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Re: Are you having problems running high compression on pump gas? (Cool32)
My '64 327/300 has been running fine with 94, no knocks, no pings, no errors.
