Where can I buy AC Delco oil filter PF35 ?
I went to Auto Zone today, as well as Discount Auto and Pep Boys.
None of them carry it.
Where did you buy yours, and how much did you pay ?
I picked up a 454 just in case I can't find a 35. The 35 is quite
a bit longer, and thus holds more oil.
Location: Retired Suffolk County Police Dept NY South Carolina
Re: Where can I buy AC Delco oil filter PF35 ? (Electron Blue '02)
They are pretty common I believe I have a few in my garage for my 96. Try Pep Boys
They are discontinued in the USA but still available from GM Canada (made in Oshawa, Ontario). I can ship you a case (12) if you wish.
AC has discontinued the PF35 and many of their other old numbers. PF35 has been replaced by the PF1218, according to kragen.com.
Alan, believe it or not I have had excellent luck looking for oil filters going to a local GM (in this case a Pontiac) dealer. One thing is for sure, if they have a Delco part, you will get a Delco part. And also, believe it or not, the prices are actually in line with the local AutoZone and PepBoys. :thumbs:
Try a local parts store, Pep boys, Aid stores are OK but sometimes :cuss :cuss :cuss
I get them at the LOCAL PARTS SUPPLY HOUSE.
Call your local places and ask. It will save you some footsteps. :D :D :D
Good Luck Have a :cheers: :cheers: :cheers:
Re: Where can I buy AC Delco oil filter PF35 ? (2 Ag R8Cs)
Re: Where can I buy AC Delco oil filter PF35 ? (paul67)
I want to try and find one locally, or just use the 454 I bought today.
I just checked my garage, I have 3 left, I guess I will have to order some from Canada when I need more.
The best direct replacement is the PF1218 developed for the 1990 ZR-1. It has an anti-spill check valve incorporated for the horizontal fit on that motor. Of course that is not terribly relevant for a vertical fit. The PF454 was developed for the 8.1L GMC V8 but will do the job.
Try NAPA if they're in your area. I believe they carry AC Delco brand. The big chains usually don't.
I'm good to go. Thanks all.
Is the pf35 the "complete" filter that they started using in 67? I still use the cartrage but I belive both have replacements available from Fram if that helps. (the cartage is hidden, so I've never worried about the logo.) I get them at the local Kragen. :yesnod:
Re: Where can I buy AC Delco oil filter PF35 ? (guycummins)
