Winter Project, 1964 Convertible
Old Mar 28, 2026 | 02:20 PM
  #281
Factoid's Avatar
Factoid
Hot damn!
Old Mar 28, 2026 | 03:24 PM
  #282
ICON64's Avatar
ICON64
It's ALIVE !!!!!!!
Old Mar 28, 2026 | 05:49 PM
  #283
Ted64C2's Avatar
Ted64C2
So I got it to idle, a tad high, even when warm, which is ok. Sounds awesome. Moves forward and moves backwards as well.
Then I noticed a coolant leak on my t'stat spacer. The plug i added wasn't sealed properly. So I drained a gallon out, resealed the plug and that fixed it.
Then restarted, it seems a bit finicky at times trying to start. Started it up, back to operating temp, good oil, good fuel pressure, etc.
Then I noticed an oil leak. The gasket on the oil filter canister was leaking (happened before when I filled it). So now I'll have to removed housing, make a real gasket, and try again. The supplied ones suck, way too thin. I may have to put a spin on filter. I do not want this to fail a 3rd time!
More tomorrow!
Old Mar 29, 2026 | 05:08 PM
  #284
Ted64C2's Avatar
Ted64C2
Made a new gasket. Will try it later. Wik ones suck.
Was able to finally free up the lift for cleaning the oil spill and then maintenance on truck and car.
Old Mar 29, 2026 | 05:35 PM
  #285
Factoid's Avatar
Factoid
Unless originality is important to you, you should convert to a spin on. A lot less issues to deal with.
Old Mar 29, 2026 | 06:43 PM
  #286
Ted64C2's Avatar
Ted64C2
Hi Mark.
Not important at all. I thought it would not be an issue for the first oil change on the new engine. I'll try one more time, and then go from there.
Old Mar 29, 2026 | 07:54 PM
  #287
Limp's Avatar
Limp
The biggest challenge with the old cartridge type filters was making sure you got the old Oring/ gasket out, on top of making sure who was there before you got the old gasket out when they did an oil change .. Best way to be sure was after you have removed the cartridge and filter was to remove the two bolts up into the block and then you can remove the inside piece the gasket/oring fits around... Its pretty easy and there is no guess work then... Clean it up, reattach it with the two bolts and install a new O ring...... At least thats how I used to do it a long time ago....
Old Mar 30, 2026 | 09:07 AM
  #288
SJW's Avatar
SJW
Live well,
SJW
Old Mar 30, 2026 | 05:04 PM
  #289
Ted64C2's Avatar
Ted64C2
I'm going the spin on route. I do not need an oil purge on a rebuilt engine! Thanks everyone.
Old Mar 30, 2026 | 11:46 PM
  #290
Factoid's Avatar
Factoid
Good move, Ted.
Old Apr 6, 2026 | 07:29 AM
  #291
Ted64C2's Avatar
Ted64C2
So this temp gauge is pinned hard left and dies not move, regardless of temp, power, ec. Im guessing its bad?
The weather has been terrible. Cold, floods. Not C2 test driving weather. Grrr.
Old Apr 6, 2026 | 05:40 PM
  #292
Westlotorn's Avatar
Westlotorn
At least you have a great shop to work in till the weather improves! Nice Progress.
Old Apr 6, 2026 | 06:25 PM
  #293
Factoid's Avatar
Factoid
Sorry to hear about the temp gauge, Ted, I don’t recall it being an issue but it was 2018 the last time I saw the cluster in action.
Old Apr 6, 2026 | 06:33 PM
  #294
Ted64C2's Avatar
Ted64C2
No worries Mark. New one on order as well as a new sender. Out comes the dash again! I do have a temp sensor on my aces as a backup.
Old Apr 6, 2026 | 06:36 PM
  #295
Ted64C2's Avatar
Ted64C2
Thank you. Im fortune enough to have that shop. Makes it a bit easier to work on projects for sure.
Old Apr 11, 2026 | 06:34 PM
  #296
Ted64C2's Avatar
Ted64C2
Bad news. Driver's side head gasket is toast. Burning oil internally and leaks some oil externally. After my business trip this week, I'll get with the builder to get her back running. Sometimes, things just go sideways.
Old Apr 11, 2026 | 06:43 PM
  #297
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Tell me about it!
Certainly not what you want to hear, but not a total catastrophe. At your rate of progress, it will be fixed in a week!
To Winter Project, 1964 Convertible
Old Apr 14, 2026 | 09:05 AM
  #298
Ted64C2's Avatar
Ted64C2
The 64 goes back to the builder this weekend. I'm glad I left the hood off!
I did install a new temp sender and temp gauge. It wasn't bad work since I've pulled it back just enough to chamge the gauge out. The 1/4-20 x 14" all-thread has been very useful for all of the dash work I've done. It took only 1 hour to change the gauge and only few curse words.
Old Apr 14, 2026 | 09:46 AM
  #299
Westlotorn's Avatar
Westlotorn
I have never seen a new leaking head gasket? If overheated they will certainly leak? I don't think yours was overheated at all so this has me very curious. Let us know what you find on this please. I hope it is something simple.
Standard head gaskets do not seal coolant well till after one heat cycle, but yours is leaking Oil?
Old Apr 14, 2026 | 09:53 AM
  #300
Ted64C2's Avatar
Ted64C2
Yes, steange. Its my guess about the head gasket. Being optimistic. It was operating at 190 on several occasions as I was trying to get Aces learned.
