Mass -Flo EFI MASS AIR fuel injection system & complete fuel system
#45
Former Vendor
St. Jude Donor '13
Mass -Flo EFI MASS AIR fuel injection system Small or Big Block Chevy
and the complete fuel system
Make no mistake... This is the best fuel injection system available. All the benefits of a MASS AIR fuel injection system with the vintage look of a 4bbl carburetor. It is NOT A SPEED DENSITY SYSTEM like other similar systems.
#49
Former Vendor
St. Jude Donor '13
#52
Former Vendor
St. Jude Donor '13
#55
Former Vendor
St. Jude Donor '13
#58
Former Vendor
St. Jude Donor '13
Kits include:
* 110 gallon/hr electric fuel pump- external style. These pumps are very high quality, and unlike most external pumps, are very quiet. An "in tank" style fuel pump conversion kit can be substituted at no extra cost.
* High flow pre-filter to protect the fuel pump.
* High flow 5 micron fuel filter.
* Adjustable vacuum/boost sensitive fuel pressure regulator.
* Fuel pressure gauge.
* 10 feet of #8 stainless braided hose, or socketless hose.
* 25 feet of #6 stainless braided hose, or socketless hose.
* All needed fittings to complete the installation.
* Insulated clamps to mount the hoses to the undercarriage.
* Instructions.
Fuel Supply Systems for MASS AIR fuel injection system
* Instructions.
System includes:
- Four barrel single plane Mass-Flo Patented intake manifold.
- Our own custom 1000 CFM 4 bbl throttle body. It features all aluminum and stainless steel construction, sealed ball bearings on the throttle shafts, and progressive linkage. Comes complete with idle control motor and throttle position sensor. This is absolutely the finest 4 bbl throttle body on the market!
- Jumbo fuel rails and mounts. Rails have 9/16" diameter bores providing excellent flow and dampening characteristics.
- Our custom compact high flow patented mass air meter. The air meter is concealed within the air cleaner of your choice to maintain the vintage look! Systems are also available with our patented Pro-M mass air meters for draw through or blow through application.
- Complete production quality wiring harness. This stand alone high quality harness allows easy installation of our EFI system into any vehicle without connecting to your existing harness. For ease of installation each harness connector is individually labeled.
- Production mass air sequential electronic fuel injection computer.
- Eight high quality fuel injectors, sized to your application. The injectors are sized to allow ample room for large increases in horsepower. These fuel injectors are held to much closer tolerance than typical production injectors.
- All needed sensors. Most of the sensors are mounted right on the injection system for a simple install. No crank sensor to complicate the process!
- High performance billet aluminum distributor complete with ignition module, rotor and cap. Our entire ignition system is contained within the distributor and ECM. Just install the distributor and plug it into the harness. No spark boxes needed. However, after market capacitive discharge ignition systems, boost retard systems, nitrous control systems, rev limiters and shift lights can all easily be added.
- High performance coil featuring faster rise time and increased spark duration for increased performance. This coil comes with heat sink and mounting bracket.
- Throttle body base gasket, throttle cable bracket, assorted hardware and fittings and detailed instructions for a simple turn key installation.
All of these components are absolutely the best quality available. Unlike the competition, we will never sell you something that is "good enough" just because it costs less to produce.
#60
Former Vendor
St. Jude Donor '13
System includes:
