Serpentine system starter kit
Want to convert to serpentine. This is a great start. You will need Alt, PS pump if you have it AC if you have it. Popular conversion and these are real nice. I have the 88 to 92 Camaro, Firebird Crank, Water pump and waterpump pulley. $100 shipped buys the three pieces. Im building a new engine. These are off a 91 Camaro that was rebuilt less than 10,0000 miles ago, I am using the short block and have my old serpentine setup. They are in good shape with minor paint bubbling in the crank pulley, Blast and paint they would look new. Overall finish is about a 9 of 10 if 10 is new. Water pump is a newer replacement with little signs of use and spins perfect with no sign of weep. These are as I removed them with no cleanup. Might have been replaced with motor. You will still need a few parts depending on your accessories and how you want to set it up. The Fbody setups are the most desireable, lower profile than the truck and fit under the hood. This will get you started cheap. The WP pulley on Ebay run about $100. Water pump pulley # 10055880 Crank Pulley #10055879 AAD. Required reverse rotation pump included.
http://www.ebay.com/itm/221717559058...84.m1555.l2649
