WTB: Help finding engine c1 !
Hi,
I am the happy owner of a corvette C1 1960, here in Europe.
The problem is that the engine isn't an original one ...
It is a 327 ci (T1122EC) chevelle's engine.
I would like to find an original engine :
casting number 3756519
suffix code : dg/dj
I am ready to send back the chevelle one.
Where can i find a (rebuild) engine ?
Thanks.
Pascal.
C1 in Franca Corta !
suffix code : dg/dj
Thanks.
Pascal.
Hi,
suffix code : dg/dj
Thanks.
Pascal.
suffix code : dg/dj
Thanks.
Pascal.
Thanks for the quick answer.
From what car is it coming from?
any suffix code ?
What would be the price?
Any photos ?
thanks
Pascal
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
maguet11020 (04-08-2017)
This block came from a 60 corvette vin10330x as stamped on the pad.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,324 Likes
This is the Cars For Sale section.
I'll move your thread to the Parts section.
sure that i am interested!
the problem is that i own a corvette with a chevelle engine. So , i don't know witch parts of the chevelle engine will fit on the corvette one !
What is your price for a complete engine ?
Pascal.
60 engine
Pascal, I have a block and crank. Can also supply oil pan and dual 4 barrel carbs. No Heads. Block will need to be rebuilt with new pistons etc. I am asking $750 fro the block and the crank only. Block is from a 60 corvette vin is 330x. and it is a 270 HP. The assembly stamp is F0I26CU. Which translates to Flint block assembled on January 26th and the CU is for 270 HP dual carburetor with solid lifters. The block was cast A230. Which is January 23 of 1960. Block was cast three days before being assembled. Block and crank are $750. plus shipping. Oil pan and carbs are additional.
two more questions :
what would be the price for the block, crank ,carburators and oïl pan?
Is there a firm in the neightbourthood which would be able to rebuild the engine ?
thanks
The oil pan would be $1000. The 2x4 set up is $2500. which includes both carburetors, The intake and the correct 891 distributor. For all of the parts $4200. plus shipping.
maguet11020 (04-11-2017)
Hi,
suffix code : dg/dj
Thanks.
Pascal.
suffix code : dg/dj
Thanks.
Pascal.
I have a 3756519 almost complete engine with suffix code F1031CU, date code J 5 0. Heads are 3774682's both dated D 29 0. Not rebuilt it is in original condition from pan on up minus the intake and dual carbs, distributor, and water pump and pulleys. everything internal still there. Let .e k ow if you want to purchase a numbers matching top rated carbed 270 hp engine for your vette.
thanks for the answer.
the problem with the CU block is to find the intake and carbs !
let me know your price and where you are located.
Pascal
