FS: 1975 3.08 rear differential. Has HD Sideyokes with cap screws and caps
This is a 1975 3.08. It will bolt right in your midyear with a transition Ujoint. Sideyoke endplay is about .040 on both sides. Gear lash is setup play only, nice, HD side yoke caps and bolts (these run over $100), front driveshaft bolts. I would go through it as it is 40+ years old. Bearings, seals, gasket, inspect but no shavings In fluid and everything seems really solid. This is a much nicer core than you would normally find and 100% complete. I will build a crate for it to ship in. I would like $500 crated. You cover actual shipping. I also have assembled trailing arms with spindles (No emergency brake) half shafts, crossmember, strut rod mount, spring mount, Gymkhana 7 leaf spring with sticker still attached, everything has some surface rust, no rot or swelling at welds on trailing arms.
Someone has to need this. Price the HD sideyokes, caps and bolts. It is crated and ready to ship. 18 x 15 x 11 #96. Crate is 1/2" and a nice unit to store diff in.
Question
It is a direct bolt in but you will need one of these: http://www.dennysdriveshaft.com/p377...t_3_732_x.html
