FS: 1967 427 Block 3904351 date code c017 stamp JE
SOLD
Price Drop Needs to go $3500.00 for both. Can deliver to Lakeland Fl NCRS or Mecum .
427 Engine Block, 3904351, Std Bore, date code c017. Still has T050TJE stamp on front pad, 4 bolt main. Purchased from Speed Shop liquidation over 35 years ago. Recently cleaned and checked by machine shop no cracks, std bore, only area of note is wear on cam sprocket thrust face. Also have the forged crank 6223 appears to be std, no other parts. Recommend inspection, Prefer pickup North Fl, Will ship on your dime. $5000.00 for both or $4500.00 for Block and $500.00 on crank. PM to setup call and details.
It measured standard from the machine shop. Don't know if it would be usable at standard after the hone and clean up. Have not checked the crank, I would assume it would need turning or used as core.
