FS: C1 Resto Mod Rolling Chassis
Here is what started as a pit free original frame.
later C4 front suspension with 12" Rotors.
X frame was partially removed and inner rails
welded in place.
Frame was fully welded.
LS Motor mounts and 6 speed tranny mount.
Original clutch Mount on frame is there for someone wanting to run A Tremec 5 speed with Mechanical Clutch.
Rear frame rails are custom and narrowed about 4"
on each side.Ford 9" with rebuilt center section
3:50 Posi with new Detroit Locker and Moser Axles.
Parallel 4 bar suspension with Coil over mounts.
Front rims are Chrome 18x7 Torque Thrust mounted
on 225/45/18 with tears being 20x10 on 295/30/20.
Chassis is set up for 335 rear.tires on a 2" wider rim with 2"
more of back spacing.
Front C4 suspension was $750
Rear End and Rear suspension was $3000
Tires and rims where $2000
$8500......Needs to go need the space.
welded in place.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,324 Likes
Must have asking price, please.
