FS: LGT-700 5 speed New in Box
Bought this a few years back for my 1965 car. Never got around to using. This is a brand new 5 speed in the box and has the upgraded micro-finished gearset. The LGT was designed efficiently to take up very little space in the tunnel and install with no fiberglass cutting. High torque capacity for big power and fast shifting. These are superior transmissions and are hard to get your hands on. $4500 or best offer
Located in Mountain View CA
5SPEEDRON (10-10-2019)
I've been trying to buy one for a couple years, but according to Jody's transmission, one of their dealers, Legend doesn't have the tooling to build the parts and can't or won't invest the money to do so. Their existing tooling is used for other markets/products. Too bad as its a great transmission.
BlackMoon (04-17-2018)
Cruise-In III Veteran
I'll 2nd what Ken said on this great transmission. Reliability, shifting ease, quiet (no gear whining). I've got going on 18,000 miles on mine. It's the close ratio version offered back then through Keisler. The ratios on mine are:
1st - 2.66
2nd -1.78
3rd - 1.30
4th - 1.00
5th - .68
Patman65, I'd post up the gear ratios of your SS700 as they did offer a wide ratio version as well.
Bump to the top for the seller. GLWS!
Regards,
Jim
In God We Trust!
1st - 2.66
2nd -1.78
3rd - 1.30
4th - 1.00
5th - .68
Regards,
Jim
In God We Trust!
Thanks for the bumps, busy at work again, just to confirm the gear ratios,
2.66, 1.78, 1.30, 1.00, .68
I know several people putting 500 hp through these gear boxes they shift fax an built to withstand abuse.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Please list your location for shipping cost purposes.
Very interested....
Do you know, can you use a factory style mechanical clutch?
Will this mount to the factory cross-member?
Does the factory drive shaft work or will a longer/shorter one be required?
I was looking for one of these a year or so ago, but when I realized they stopped making them, I gave up.
Thanks for the info!
Very interested....
Lgt 700
Emi,l here in central N.J. Do you still have trans available? I currently have one in a 66 Biscayne with a 511" Gen VI and could not be happier.
Let me know and thanks! You can call me at 908-507-3032
Lgt700
[QUOTE=Patman65;1596974705]Bought this a few years back for my 1965 car. Never got around to using. This is a brand new 5 speed in the box and has the upgraded micro-finished gearset. The LGT was designed efficiently to take up very little space in the tunnel and install with no fiberglass cutting. High torque capacity for big power and fast shifting. These are superior transmissions and are hard to get your hands on. $4500 or best offer
[/Is this transmission still available?]
