FS: Tom's 12 Bolt, 1480 Half shaft kit and offset trailing arms
SOLD SOLD SOLD
Tom's 12 bolt posi rear end w/new 3.73 gears, 1480 axle kit, rebuilt offset trailing arms with slip fit bearings, 31 spline outer axles and 1/2" wheel studs (5/8" available if wanted). Stainless parking brake hardware and new shoes. Spare poly trailing arm bushings and set of stainless steel alignment shims included. Zero miles on everything since refresh. Only reason for selling is I'm going with an aftermarket frame.
Here are links for additional info on this setup:
https://www.vansteel.com/index.cfm?f...p=3031&ID=3272
https://www.vansteel.com/index.cfm?f...&SubGroup=3020
https://www.tomsdifferentials.com/20...Pages14-23.pdf
Located in SF Bay Area. SOLD SOLD SOLD
