FS: LS3 Restomod Kit, plus EFI Fuel Tank & Radiator.
LS3 6.2L GM Crate engine 19257234. Less than 1000 miles on it.
Upgraded camshaft. Detroit Speed p/n 25-TSP231246. Duration 231/246. Lift .640"/.615. LSA 109. ICL 112
Detroit Speed Spring kit p/n 199-PACPOL660
Detroit Speed Push Rods 25-7400
March Performance Pro-Track Serpentine Kit p/n 20035
Engine Control Module, Headers, Air Filter, Engine Covers, Flywheel,
Bellhousing and Power Steering Reservoir
GM Hydramax Hydraulic Clutch Actuator System
EFI Gas Tank and Fuel Pump
Tanks Inc TM-33A-T conversion EFI tank. GPA-4 pump, good for 600hp. Fuel filter is included
Aluminum Radiator with Electric Fan
manufacturer ?
All of the Items for sale have less than 1000 miles on them before being removed from a C2 corvette. Nothing wrong with the engine or any of the other parts at all, It runs great. Just decided to go in a different direction with a 572" aluminum big block.
Asking $7300 for everything or I will sell items later separately. (Summit Racing sells this engine for $9100) All parts are located at Fabulous Restorations in Fort Lauderdale Fl.
*AC pump not included.
manufacturer ?
Ttt
This should work nicely [img]blob:https://www.corvetteforum.com/bdd6cf02-e28f-4623-a759-f74019f8df6f[/img]
Pic will not load from iPhone. Will post later
Okay, this is going in the swc. It will look like an L88 when done. I will start a different post later on this
nfran (02-20-2020)
Keith, PM sent
Ls3
Interested in your set up. Still for sale? I have a few questions. Can you email me at pvhoops1@gmail.com or give me a call at 530-570-5108. I have a 63 convertible.
I got some nibbles, but yes its still available.
430 hp and 425 ft lbs of torque before installing Detroit Speed camshaft. Here's a couple link.
www.chevrolet.com/performance/crate-engines/e-rod-ls3/17-tooth-reluctor-wheel-
https://www.summitracing.com/int/par...7234/overview/
I sent you a PM.
SOLD to CF member.
