Stahl headers for Grand Sports
Attention Grand Sport owners. Stahl headers now has a side exit small block header that was designed for Mid America Grand Sports but should fit your D&D cars and other makes as well. Its available in 1 5/8 -1 3/4 and 1 3/4 -1 7/8 (stepped header) and will be a "custom fit" header for your car. It will include the curved extensions leading (header and extensions all 1 piece) to a separate side pipe (supplied separately). The procedure is: Stahl Headers will ship you the mockup header for fitting. It is purposely built low to accommodate different cylinder heads and engine installation. After installing on your car, you determine how much higher you want your header built. You will
measure the header to frame rail clearance and the curved extension to rocker panel clearance. Send the header back with the measurements and they will custom fabricate your header. If your cylinder heads have been ported, send along a port template so Stahl can use the appropriate flange. This will allow for a perfect fit for each different small block head configuration and any variances in each car. You will also be able toadjust where you would like your side pipe located relative to the body of the car. Now GS owners have a quality equal length header that is custom made for you. I am on the list and have seen them on the car, they look and fit great. Stahl Headers phone is: (717) 846 1632
