need an Electric guru 4 taillight ? - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 04-02-2005, 02:32 PM   #1
Todbo
CF Senior Member
Todbo's Avatar
Default need an Electric guru 4 taillight ?
Ok , here's my latest bug , I have new wiring thru out my car , new bulbs. My stop light/tail light on the pass wrks correctly, on the drv side the running light wrks fine , but when I apply brakes the drv side lights up the upper/thinner/dimmer element (tail light element), and the pass side lights up the bigger/ brighter element. Checked connection underneath seem to be only one way wires can be installed ,and they were the same way on both sides, switched bulbs around , checked and cleaned grnd. Ok , what do you think guys/gals ?
Todbo is offline   Reply With Quote
Old 04-02-2005, 08:51 PM   #2
Lotus76
CF Senior Member
Lotus76's Avatar
Its Fixed!
Quote:
Originally Posted by Lotus76
This is a strange one
It almost like the tail lights and the brake lights have changed jobs... or voltage anyway. My taillights function fine (come on when the brake pedal is pushed) but kind of dim. The turn signals function fine too, but also kind of dim. When I turn on the headlights (and taillights) for night driving the taillights are very bright, so bright that you cannot tell when the brakes or turn signals are activated.
Strange huh?
Now I have done many things to the Vette this winter ... one being transforming the automatic to a 4 speed, the dash was out the steering column was out too. one more strange thing is my tach acts flaky ( jumps around at low speed and never reaches higher RPM)
Before the winter I built a new tach filter and it seemed to work fine then.
is there something I could have plugged in backwards? Do I have a bad ground? a bad switch?
Where are the grounds anyway? any tips on trouble shooting this? Anyone got a good schemantic? mines pretty small print.
This is dangerous I almost got rear ended last night. Can you help?
Thanks,
John
Well its fixed...
After a lot of studying of the schematics, tracing circuits, reseating plugs, adding grounds and inspecting sockets I discovered the problem...
Get this... The lamps where in the sockets backwards
I didnít even know this was possible but it was. The 1157 lamp has two filaments and two contacts at the base of the lamp and uses the shell for ground. 1157 has two bayonets; one mid shell and one low on the shell. The socket has two slots for these to mount in than twist.
Foolproof right? NOT! You can install the bulb wrong and the problem you get is the wrong signal sent to the wrong filament. Each filament has different lighting properties (one will be brighter)
You know just when you think you know a little about Vettes they humble you to keep you straight
Thanks for all who responded to this thread.
John
__________________
A Toast: To internal combustion, and wind in the face.
1976 Red Corvette Stingray 4 Speed
Lotus76 is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • need an Electric guru 4 taillight ?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Only one Brake Light? GRipp 73 C3 Tech/Performance 12 07-21-2013 11:37 PM
    New battery after winter..nothing wrks klymaxr C5 Tech 5 08-06-2011 09:55 AM
    1962 Tail Light Problems OldSchoolSS C1 & C2 Corvettes 5 07-27-2009 11:32 AM
    '64 tail lights or lack there of Dad_98C5 C1 & C2 Corvettes 8 09-23-2008 07:16 PM
    Brake Light Out Tom Austin C1 & C2 Corvettes 12 07-03-2008 03:02 PM
    Tags
    1976, corvette, dim, light, stingray, tail
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
