De-Gunking. There has got to be a better way?
Old 04-03-2005, 04:37 PM
stingray_jim
stingray_jim's Avatar
Default De-Gunking. There has got to be a better way?
Hi Guys. Just spent an hour + trying to de-gunk my bell housing (out of car and unattached). I used, Greased lighting some other degreaser and resorted to Kerosene. Scraped with a variety of still and stell bristled brushes. I still have good film of grease over the surface. Would steam cleaning get this? A power washer? Wire brush on the drill for the final surface clean?
Any tips are greatly appreciated.
Many thanks.
Jim
[IMG]
Old 04-03-2005, 04:40 PM
WESCH
WESCH's Avatar
Hi
A steam cleaner ( very hot ) will do the job , probably much better than any diluter solution.
Günther
Old 04-03-2005, 04:44 PM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Spay the degreaser on and walk away for about 20min. Come back with a stiff parts brush. Almost all should come off.
Old 04-03-2005, 07:33 PM
joe73vette
joe73vette's Avatar
I use this stuff called Gunk SC super concentrate. You mix it with mineral spirits or kerosene, and it cuts thru the gunk and you hose it off. Joe
Old 04-03-2005, 09:53 PM
EDDIEJ82
EDDIEJ82's Avatar
Oven Cleaner works great on greasy parts. Just get the cheap dollar store kind, it works better.
Old 04-03-2005, 10:09 PM
blackbeauty74
blackbeauty74's Avatar
I agree with the oven cleaner.
Old 04-03-2005, 10:27 PM
isosceles
isosceles's Avatar
Me too. I used Easy Off last time. Unbelievable compared to Gunk.
Old 04-03-2005, 11:18 PM
markdtn
markdtn's Avatar
Pressurewash it best you can and then Castrol Super Clean. I buy it by the gallon and use a hand pump sprayer to dispense it.
Old 04-03-2005, 11:20 PM
C3Curves
C3Curves's Avatar
wow..good idea on oven cleaner. Saved me a lot of time..
Old 04-04-2005, 07:48 AM
stingray_jim
Default Thanks
Off to the supermarket for some oven cleaner.
thanks
Jim
Old 04-04-2005, 08:08 AM
MILO
MILO's Avatar
If it's not caked on grease, but only a film which could meesed up the paint job, I've always gave my parts a quick squirt down with brake cleaner. Start top to bottom. Hit it with a water hose and air dry. If you have a air compressor to blow it off all the better.
Old 04-04-2005, 08:16 AM
jimvette999
jimvette999's Avatar
A machine shop will clean items like that for less than you'd think. Prob. about $10. If you count your time and materials it's worth it. I find that gasoline works well when I do clean stuff like that at home.
Jim
Old 04-04-2005, 08:31 AM
norvalwilhelm
norvalwilhelm's Avatar
How about going to the coin operated car washes and use their shoppy water and pressure to take the majority of the junk off ?
Also like someone already said take it to a machine shop and let them clean it. I don't know about hot tanking it because it is aluminum but some have gone to something like a dish washer. It does a great job.
Old 04-04-2005, 09:03 AM
70BBvert
70BBvert's Avatar
I sent mine to one of the shops we work with & had them clean it. Came out pretty good, then I cleaned the rest with Marine clean from POR-15, wire brushes & scrapers. Then glass beaded & painted.
Jim
Old 04-04-2005, 10:51 AM
vettfixr
vettfixr's Avatar
For really tough grime spray some degreaser and let it sit for a while. Rinse it off with hot water. Whatever remains can be cleaned by using cookies on a die grinder. I did my bellhousing like this and was almost tempted to buff and polish it when it was done. You can get the holder and cookies from an auto supply store. The cookies come in different coarsness grades too so you can use an agressive one to clean big chunks of baked on grease and finer grades to clean off the paint without removing metal.
Old 04-04-2005, 01:50 PM
jimvette999
Those 3M Roloc discs work great. Kind of expensive but well worth it.
Old 04-05-2005, 04:57 AM
Desertdawg
Desertdawg's Avatar
St. Jude Donor '09
Jim
Your a braver man than me...
And yes I have used gas before, let me tell you, it will still flare up even after you think it's all dry...
To De-Gunking. There has got to be a better way?
Old 04-05-2005, 05:11 AM
joes79
joes79's Avatar
St. Jude Donor '05
Default Keep this in mind when using gas as a cleaning agent!!
Gas doesn't burn. It "EXPLODES"
Old 04-05-2005, 12:20 PM
DJ Dep
DJ Dep's Avatar
St. Jude Donor '05-'07
LOL...ditto for me and gas. It works quick and easy and cleans like crazy. Plus I like the smell
I like kerosene out of a compressor sprayer, but it does leave a light oil film.
Dep
P.s. Hey DD...I heard you looked like Michael Jackson with his hair on fire when it flared up!!!
Old 05-06-2005, 04:23 PM
Buzzardz_vette
Buzzardz_vette's Avatar
How does it work on painted parts? Does it take of the old paint?
Quick Reply: De-Gunking. There has got to be a better way?
