Aftermarket Guage Question
Old 05-09-2005, 09:06 PM
corvettecris
corvettecris's Avatar
Default Aftermarket Guage Question
What size fits in the console? I assume 2 1/16, but I just wanted to be sure. I am looking at the Auto Meter Cobalts. Anyone mounted these, or similar? What mods (if any) are required to the bezel?
TIA
Old 05-09-2005, 09:32 PM
Silver00V6Camaro
Silver00V6Camaro's Avatar
Yep 2 1/16 works perfect here is mine they are sport compact by autometer.
Old 05-09-2005, 09:42 PM
Jclgodale3
Jclgodale3's Avatar
and here's mine Phantom's straight in
and on a 13 degree angle towrds the driver
Old 05-09-2005, 11:11 PM
rosslato
rosslato's Avatar
i went w/the phantoms also. i also went w/the angle rims due to the fact that a couple of the 2 1/16th gages fell rite thru my bezel holes but i really like the angle rings
Old 05-10-2005, 06:44 AM
corvettecris
WHere did you get those angled bezels?
I am looking at the COBALT guages. I think I saw someone else around here with them. Is the wiring a nightmare? I would imagine it's quite simple.
Old 05-10-2005, 07:46 AM
PatsLs1vette
PatsLs1vette's Avatar
i installed the phantoms in also and added an air fuel ratio guage too,they work great and look way better.
Old 05-10-2005, 09:07 AM
Jclgodale3
Jclgodale3's Avatar
the angled bezels can be bought most places you get the gauges, Jegs, Summit etc. Check under gauge hardware or mounting. (got to buy in sets of 3 I think) I made mine out of about $1.50 worth of PCV pipe.
Old 05-10-2005, 10:40 AM
rosslato
rosslato's Avatar
i got em from summit, they come in a package of 3 for $7.88 plus $9 for handling but no shipping charges, been paying summit a lot in handling charges lately. i'll find u the wiring link and send it to u
Old 05-10-2005, 10:43 AM
rosslato
rosslato's Avatar
excellent job on your angled bezels, looks great, very professional
Old 05-10-2005, 10:51 AM
rosslato
rosslato's Avatar
heres the link for the instructions i got from DMONSVETTE. http://earchitect.50megs.com/corvette/gauge.htm
Old 05-10-2005, 10:53 AM
79ls1
79ls1's Avatar
I have the Cobalts. I can't post them right now as I'm at work, but if you look under my recents posts, you should be able to find a pic.
They are all 2/16, the only thing you have to do to the faceplate is grind out a little, The wiring isn't bad, just get a good schematic for your particular vette. I butt spliced/insulated all the sensor wires and used a good solder joint to bundle the power, light and ground wires. The Cobalts come with their own harnesses that you plug into the back of the gauges.
Old 05-10-2005, 11:21 AM
corvettecris
I looked, but no luck. Can you re-post when you get a sec? Have any shots at night time?
Old 05-10-2005, 01:35 PM
mrtroutjedi
mrtroutjedi's Avatar
I used the Auto Meter z series and add the air fuel gauge instead of a clock looks cool 2 1/16 gauges I think
Old 05-10-2005, 08:49 PM
79ls1
79ls1's Avatar
OK, here they are, sorry I don't have night shots, they look awesome lit up.
http://img.photobucket.com/albums/v5...shfromleft.jpg
http://img.photobucket.com/albums/v5...olecloseup.jpg
I goofed in my writing, I only butt-spliced the oil pres, volt and water temp sender wires to use the original harness. The rest was run whole as a new harness.
Old 05-11-2005, 03:14 PM
Joebio
Joebio's Avatar
79lsi Do you have any pics of your dash, I see you added 3 more guages there, I would like to see what you added and how it came out.
Old 05-11-2005, 03:55 PM
corvettecris
I ordered my Cobalts today. I decided to go with an A/F meter to replace the clock.
Old 05-11-2005, 07:52 PM
79ls1
79ls1's Avatar
http://img.photobucket.com/albums/v5...hfromright.jpg
I really don't care fot it and am going to just have 5" tach and speedo when Autometer comes out with them in the fall and go with the original faceplate and indicator lights.
To Aftermarket Guage Question
Old 05-12-2005, 09:17 AM
Bluewasp
Bluewasp's Avatar
NoVa Events Coordinator
St. Jude Donor '14
Autometer is making 5 inch cobalt speedo and tach? Nice!!
Old 05-12-2005, 09:19 AM
Bluewasp
Bluewasp's Avatar
St. Jude Donor '14
Did you try to install the cobalts in the stock location??
Old 05-12-2005, 10:57 AM
79ls1
79ls1's Avatar
That's what I intended originally, but right now the tach and speedo only come in 3 3/8", so I tried a compromise. I didn't think that the smaller tach/speedo would look very good by themselves. That, and I saw them lit up at the store, went ape sh#@. You sometimes don't know if you'll like something until you see it. I like Fauxrs setup much better, so I'm going to do a version of that.
Quick Reply: Aftermarket Guage Question
