Reason to save stock radiator?
Hey guys, I am in the middle of a engine swap and I just pulled the 24 year old radiator out of my car. It doesn't look too bad, but I have a Dewitts ready to go in when the other engine is in. Is there any reason I would want to save the old radiator? It has some scale/rust/corrosion on it, but it wasn't leaking when I pulled it. I am saving everything I pull off in case someone want to take it back to stock eventually, but would they really want the old radiator? Here are shots of it:
http://www.everyonefly.com/html/may_9th_2005_6.html
http://www.everyonefly.com/html/may_9th_2005_7.html
TIA,
-B
TIA,
-B
Drop it into the trash can radar unit. Perhaps the cops can find a use for it...
If I kept all those numbers matching parts, my garage would look likie a dumpster. Future generations -- sheesh.
I still have the original radiator from my 68 427, non ac car, I now am running a 502/502 crate, same radiator, and have NEVER overheated. No special fans, in fact , Im using the oem fan/clutch. I do have an aluminum water pup, but thats it. Even with the original h2o pump, never overheated. No prob when I was running my 427 either, Still running a 160 stat, both on my 427 and 502
I dont have probs with oem radiators. They are heavy, but I dont have a reason to change out
The key is, recore it if it hasnt, and change fluid EVERY year (I do it twice a year)
Senior Member since 1492
Originally Posted by DropTopBigBlock
you kidding? put that thing on ebay--should get you a cool mil . . .
Naw, but maybe my 30 year old shocks.
Originally Posted by Marv
It can always be re-cored by a local radiator shop and then you know it will fit when/if it gets re-installed. I'd save it if you have room to store.
Hmm, cooling blues
Damn, I can't get my 71 454 to run at a moderate temp! I finally dropped back and punted! I ordered a DeWitts unit, I have yet to fit it, but I hope it works. I have a new stewart Alum pump too, it didn't help. I guess Texas is too hot for vettes...
carbster
carbster
I've got mine in the garage with all of that other crap taking up unecessary space. I don't know why I can't bring myself to just trash it. It will never go back in, never leaked either.
carbster
carbster
The way to go. DeWitt's.
Originally Posted by yellow73sb
I traded mine for chrome hooker side pipes.
Former Vendor
Originally Posted by tersian
Is there any reason I would want to save the old radiator? -B
My Radiator is still the stock small blk that came in the car in 1969. never been recored, but looks like it had been cleaned out before I bought the car. I am running a 421 stroker with flex fan and Edlbk Alum water pump, and run my timing at 36 degrees with NO overheating problems or any leaks. I run a 160 thermo and it stays right at 160 to 170. I have hit it with a lazer heat gun and the warmest any of my readings said was 185 at the heads and they are Alum.
I say have it cleaned and use it. then you would be able to spend the extra money elsewhere.
I have a Dewitt's direct fit with dual SPALs already attached sitting in a box just waiting to drop in. I think I will hold on to the radiator and store it with the AIR pump which should be worth about 6 million dollars on eBay in 10 years
