Column Mounts for Gauges
Old May 20, 2005 | 10:21 PM
WhichVette?'s Avatar
WhichVette?
Default Column Mounts for Gauges
Do they make them for the small gauges? I'm getting an air/fuel gauge, but the only good spot I see for it is on the column between the speedo and tach. I haven't seen small gauges mounted there.
Old May 21, 2005 | 10:44 PM
WhichVette?
I'll take that as a no...
Old May 22, 2005 | 01:36 AM
corvettecris's Avatar
corvettecris
Part # ATM-2204 at Summit. Holds 2 1/6'' guages. Will that work?
Old May 22, 2005 | 02:54 AM
onaqwst's Avatar
onaqwst
u can try to find a pillar gauge pod that sort of fits and use a heat gun to warm it up and mold it to fit the contour of the pillar
b
Old May 22, 2005 | 05:17 AM
WhichVette?
That mounting cup look like it has a countour that just might work ok with a little massaging. As for the pillar, I'm not sure I could bring myself to mount gauges there, but I'll get it open as an option. Thanks guys.
To Column Mounts for Gauges
