Does yoru dynomax cermaic header look like this?
installed about a year ago on a NW ohio daily driver
is my car the cause, or is the coating crap?
Found this quote:
"Quality ceramic coated headers from Dynomax.
Dynomax ceramic coated headers have the performance you crave at a price that won't break the bank. They're computer-bent and leak-tested, have die-cut exhaust port flanges, and machine-formed and hand-welded primary tube ends for unrestricted exhaust flow. Another feature is a bright ceramic coating by Jet-Hot inside and out that not only looks good, but will last forever. "
Originally Posted by rihwoods
Found this quote:
....or untill the first snow storm
Originally Posted by Russ Bellinis
Does Dynomax guarrantee the Jet Hot coating to last forever or is that just advertizing hype?
Time to make a call for a replacement.
Dep
I would check to see what the fine print is on the statement " will last forever"
I would think that statement applies only to manufacturing defects, and would not apply to other mechanical reasons. If it was found that brake fluid was dripping on it, or that it was rubbing against a steel cable, or a symptom such as was described with the possibility of a cylinder heat causing this, then it may not be covered.
If the ceramic coating is chipping or flaking off, like you show in your photo, then the cause may be improper treatment of the headers, and should be replaced.
Do you think you can find your receipt? Then log onto the website and see what the limited warranty conditions are.
kdf
kdf
Well that just stinks. I have read and seen this before with Dynomax coating. I have Dynomax headers too, but opted for the black style and had an industrial shop coat mine.
Contact them!
Start out nice and if necessary ask for a supervisor and start mentioning that you have the attention of potential customers on this forum....
I like to think most vendors oare on the up and up and will stand by their product.
Good luck and keep us posted
Went to their website and found this:
Dynomax Headers
Dynomax Headers carry a 90 day warranty against defects in materials or craftsmanship. Any modifications to the product, or use inconsistent with the intended application, voids this warranty. Parts and Labor are not covered.
I don't know where the "last forever" quote came from. If it's from a magazine, then that's an OPINION and not a guarantee. You are past the 90 days so you are probably scrued.
Dep
Dynomax Headers
Dep
St. Jude Donor '11, '16-'17
Originally Posted by VolVette
I've had mine for 3+ years and although they don't have their original luster, the coating has not come off and they don't look anything like that. I'm sorry to see that.
Dynomax Headers
Dep
Dynomax Headers
Dep
http://store.summitracing.com/defaul...4923428+302002
When I bought mine I knew I read that somewhere but could not remember where.
