Sorry DeWitts----(this Sucks!!!!)
Well About 3 weeks ago I finally finished the install on my brand new DeWitts Aluminum radiator package with dual spal 11" fans kit.....I have had some mild overheating problems since I put in my AR 383/440 hp stroker motor.......The radiator came mounted with the fans and a nice radiator shroud. After installing the package it really fixed my cooling problems and looked real nice in front of my new motor..........Time to go cruising.....Well to make a long story short:
I was driving home from my dads house after a productive tuning session when: grrrrrrrrr////fttttttttpptptpptp///bap.bap.bap....WTF????? luckily I was just about a block from my house, so I grimaced my way into the garage and checked it out......no leaking fluids, no weird smells, the motor didn't die..........BUT My left front wheel was real **** eyed----top was in and bottom was sticking out I lifted the hood to find that my supsension had somehow broken and slammed into my brand new radiator Broke the left fan.....Broke the shroud and all but tore the wiring apart......So my brand new Dewitts radiator set-up is all F-ed up...Sorry Tom for screwing up your fine workmanship I am so mad that the car is in semi-permanent park mode....I am done with that POS for a while...
Yea that really sucks, I hope it can be fixed without too much trouble, take a break for a while and just be glad you weren't on the highway going 100MPH
I'll bet the bolts came out. I have seen it a few times before when guys bolt in new bushings, or remove the control arms for any other reason.
Senior Member since 1492
But how could that happen if they were torqued down. No previous symptoms?
That is bad news. On the good side you got home, and have the car in the garage, rather than on the side of the road and had to have it towed in.
After your short break, is this something that you will try to fix yourself?
kdf
kdf
kdf
kdf
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
1 Post
That what I was thinking also
Man I hope this don't burn you out
I know I'm burnt out of putting parts(money) on my car
and nowhere close to done
Originally Posted by paul67
Frame problems?
1 Post
Finally I somehow managed to get a bolt stuck in there, most of the the way in. I snapped off the head, turning the bolt into a stud and ran a nut down on it. It's holding the bushing in and is remaining tight. One of these days I'll get up to Van Steel and have the shaft replaced.
Front Suspension Woes
Don I had a similar instance last year while attending a Vette show in Savannah GA. We trailered the car down to Savannah from N. Ga. we normally drive down every Spring for this yearly show. Anyways we unloaded the car and headed off to meet the local club hosting the show. About 9:00 PM after a large meal me and my wife headed back to the motel for some RR to be ready for the Sat show. About a mile up the road I hit the brakes and "BAM" and the car suddenly turns left. This is a 66 BB car highly modded with "Big" tires and wheels. I get out and the first thing I see is the top of the tire leaned "way in. "Dam" did I break a ball joint? Turns out that the front bolt on the upper A-Arm had fallen out, Nadda-Gone Disappeared and the A_Arm shifted forward. The car had been fitted with poly bushings, I was very lucky the only damage was a cracked fan shroud. With a little help from friends we got her back together that night with the Aid of a few Bud Lights and made the show. Hopefully your problems will be minor. Sorry to hear your bad luck.
