Can I use OEM U-Joints with the 330HO Engine?
Canadian Events Coordinator
Can I use OEM U-Joints with the 350HO Engine?
Can I use OEM U-Joints with the 350HO engine?
I don't think I need Spicers.
Opinions?
Thanks, Les
Opinions?
Thanks, Les
1 Post
If you're not running slicks there shouldn't be a problem. The stock ujoints should handle tire spin.
I'm using Brute Force from a local parts store (probably no better than stock), even racing the 383 on sticky tracks. I think Spicers are better, but since I'm not running slicks there should be no problem.
Originally Posted by page62
Better that your ujoints blow than that potentially fragile "lightweight" Dana 44 diff they started using in 1980...
I'm running Brute Force U-joints in the '81. I have also upgraded my 350 HO crate motor with a LT4 Hotcam. Over 400 lb ft torque at the crank. Haven't had any issues yet. Plus I don't make a habit of side stepping the clutch at 4000 either. lol.
Darryl
Darryl
Stock u-joints will be fine...as long as they aren't 25 year old stock u-joints if that's the case you might want to swap them out with new stockers or get Brute Force if they aren't too much more
