Radio instal
I replaced my stock unit with a USA 3 and the sound sucks with this thing if I had it to do over I'd have the stocker redone. It is an all day job and the two studs going into console are a true nightmare. I pulled stock unit out passenger side after every thing was loose. It is like a puzzle and I found it best not to tighten anything up until all pieces are in place. The assembly manual shows gage cluster in place befor radio goes in. The speaker on drivers side will keep you cursing too..good luck
