I went to the shop and plugged my Makita buffer into the variac and I could control the speed by dropping the voltage. At 45 volts the buffer began to surge but the speed was being controlled by the applied voltage.
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Originally Posted by comp
I'm planing on making a pulley system on mine to change the speeds ,,3 different size's ,,need sure what yet but this is food for thought so i don't waste money
I have plans to build one from a shaft and two pillow block bearings and a multi speed pulley in the center to allow different speeds.
The plan is to build a small stand with an electric motor mounted in it and a belt to the top shaft. I also want to have the shaft made friendly to quick change of buffer, wire wheels and a special plate made to allow me to put a Chevrolet wheel on it for sanding and polish.
