'77 Q-jet vaccuum diagram?
Anyone know of where I can get one? I've got to reconnect my vaccuum hoses to a Edelbrock 2101 intake. This is the no-EGR version. I don't want that emissions crap on my car but I need to know which vaccuum lines get dropped because of it.
Same problem .. sort of!
The vacuum hoses on my 71 LS-5 where a mess when I bought it. I could not figure out what went where and how! I bought a new set of hoses from Doc Rebuild and the set came with a nice diagram. Also a diagram is in the catalog, which you can maybe check online! Search for Doc Rebuild or Rebuilt and corvettes, I forget the www, address.
Good luck
carbster
Good luck
carbster
http://docrebuild.com/
I've bought several kits from Dr. Rebuild over the years. His diagrams are easy to read and in color. I would recommend the kits to anyone.
The egr port is on the right side of the base plate beside the mixture screw pointing to the rad cap. The entire egr circuit is from this port to the tvs on the thermostat housing and then to the egr.
Mike
Mike
