Show me your H-Pipe!
I'm about to bring my car to an exhaust shop and would like to bring a pic to show the general location of the H-Pipe to be installed. Shop owner has Vette experience, but insists the H-Pipe must go toward the rear. I know I've seen some on here that were somewhat in the middle of the car.
My car is '74 auto, SB, lowered w/2.5" Allen's exhaust.
Thanks in advance...
It is up forward...just behind belhousing...under tranny
Originally Posted by Kalway
wtf are catalytic convertors doing on a true dual setup? :o
You can put it a little behind the crossmember, that's the way it is normally done w/ headers.
The 76 & 77 Chevy manuals mention duals for Corvettes & the 77 has a pic. w/ no cats.
Wonder what state(s) you did not have to have a cat back then ??
Rich
Not what I want to talk about on the forum. Suggest you delete it & will answer privately.
Originally Posted by TimH
Bad, bad question.
Rich
Location: San Diego - Deep Within The State of CONFUSION!
The H-pipe also was installed just aft of the trans crossmember on the '80 L48. I had installed the 700R4 conversion so I am not sure if that contributed to the placement or not. I believe there would have been ground clearance issues if it had been run ahead of the converter cover or before the rear trans mount.
Great pics. Just what I was looking for.
Whaddya think of using these for the "H" section?:
http://www.drgas.com/Ball-Cone-Adapter-Joints.asp
Many thanks.
Many thanks.
"Rodstoration &am p;quot; In Progres
Originally Posted by norvalwilhelm
This is my 3 inch crossover in a 3 inch exhuast. The crossover could have been 2 1/2 and worked just as well. It is directly behind the crossmember
Originally Posted by 80TexasC3
What kind of improvement can I expect from an H-pipe?
Many thanks.
Many thanks.
Originally Posted by Gordonm
That is called a ball and socket joint. It is what is on mine and PRNDL cars. The same shop did both of our systems.
Why different locations in the crossover between your car & PRNDL's?
