Few question about 81 model.
Hi. I have some problem about the headlights, when i turn them on after few sec will the right light go up but the left will stay down, sometimes the left will come up after some time... anybody how can give me any tips.
Which online shop is the best, i´m going to buy everything new interiors.
I´m also looking for key for my Alarm system, does anybody know where i can get him, buy new or something.. Please answer any of this questions if you know the answer.
Thanx Toni
Thanx Toni
You have a vacum problem with your lights. If the hoses haven't been replaced you need to buy a kit and replace them. You also probably need to replace the seals on the actuators, which usually comes with the hose kit. Mine did the same thing and my seals were so bad I didn't understand how they worked at all! A couple hours of work if you've never done it before. Larry
For a vendor that has the parts you need check the online catalogs of some of the supporting vendors. I use Ecklers for most of the parts I used on mine also Zip.
Here's a vacuum troubleshooting guide:
http://209.183.231.72/corvette-101/vacuum.htm
That will help you find out where the vacuum is, you may not have to replace everything. Since it's only one headlight with trouble it's like in the hose leading to the actuator or the actuator itself. When they won't stay down and the troubleshooting points to the actuator itself, it's the diaphragm inside the actuator, which usually means replacement time, about $100.
Time to get a handheld vacuum pump, if you don't already have one.
There is some problem whit my Fuel Gauge, the needle is always jumping up and down, shudder up and down. does anybody know what is wrong.. It is also in Speedmeter always jumping up and down....
