Door Liner adhesive (77)
Well, one more bubba-ism has been abolished! I found that the reason my scisscor assembly was running interference is that the bubba who had the car before didn't put the motor/lift assembly in right (the little metal tabs where not in their slots, and the rust marks where the screws should have been where a dead give-a-way.
Now, that I'm re-assembling the door, I was curious what I should use to re-glue the plastic liner back to the door? I have two different types of gunk there now, and I would love tips to remove it (one is black, and one is white -- the black is hard and needs to come off).
Also, does it seem like an extreme angle that the anti-rattle bumper towards the door handle seems to sit at? I looks to be about 30 degrees, and just seemed a little much -- that seems to be the only way it fits, but I was curious just the same.
Brian.
Brian.
Brian.
Brian.
I would have suggested the butyl rubber windshield sealer.
You can stretch it thin and use that. In the past, I have simply
used tape on my vehicles ... duct or packing, but you need a clean surface.
The pads have a mounting hole and a tab. The tab fits into a slot in the door for out & in adjustment. They may twist a bit when you tighten if the tab hole is worn....but only one way/angle to mount them at.
Eddie
Eddie
