Ordered a bolt on scoop for my '68...
On a serious note.. I will have the scoop painted in the color of the car (blue/white)
The car would even look & run better with black sidepipes rather than the "poser" chromes ones you have now.
Originally Posted by DJ Dep
My vote goes with Blue and White
AND DREMEL DECAL!!!!
Dep
Dep
hmmmm.. DREMEL RACING TEAM
Originally Posted by red79vette454
Did you ever run without the sidepipes? Mine, with mufflers weigh 25 pounds each.( Minus 50# = .050ET less.)
Another way to loose 50 lbs is to go with Aerospace brakes.. The rotors and calipers from aerospace take about 50 lbs off the front... That might be my next mod.. However, when already running very low 11's that 100 lbs = .1... I know that on a 12 or 13 second car it is true, but the faster you go, the less effect has weight reduction.. (or any other mod)
St. Jude Donor '07
I have one of those sitting in my shop on a 68 hood and a original l-88 hood but there not mine but i can use them
Don't want to risk of having cold air being sucked in and burning my exhaust valves... Need to have at least headers installed...The header part is the heavy part of the sidepipes... The side tubes are only about 10 lbs (or less) each... (I have no mufflers in them, so they are pretty light)
I would think that with only 1/8" clearence above the carb you are loosing alot of power. Have you tried taking off the hood and doing a pass just to see how much difference it makes?
#34
#35
#36
Originally Posted by Jughead
I see a supercharger in your future.
#37
Senior Member since 1492
I see one too.. but only in 2 years and it will be a blown big block
Couldn't have said it better myself.
#38
St. Jude Donor '07
i like super chargers better. this guy down at my shop has one running 35psi and it sounds like a bat outta hell. better than the blown big block a few shops down.
